Question about Lasko 5812 Heater
Clean lasko 5812 heater
Clean the air intake filter
2 Suggested Answers
SOURCE: How to clean filter on Lasko tower ceramic heater
Thanks for the response = I blew the filter clean with a forced air canister.
Posted on Dec 01, 2008
Lasko 5160 heater
it is necesary to clean the filters about one time per month ,with watter and soap,but if in your area is too many dirts so you can clean one time per week.you can see that when the power of the fan is too low.
Dec 10, 2013 | Heating & Cooling
Find filters on a kenmore miser 6 gas water heater
1) Are you looking for air intake screen located on bottom of water heater? Clean with compressed air or feather duster.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Kenmore water heaters are made by AO-Smith/ American
Stand 3-legged water heaters are bricks so air intake is easy to clean.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 29, 2012 | Water Heaters
I have a Lasko model 5420 compact ceramic heater and would like to clean the interior . There are 4 screws that attach the back, 3 are philips head but the fourth is a head design I don't recogniz
Requires a special security screwdriver. I modified a slim old screwdriver by filing a small V in the middle of the blade. You can also buy 1/4" driver bits at Harbor Freight, etc.
Jan 07, 2012 | Lasko Heating & Cooling
I have a Convector 417 RC-417-80 that starts fine but after about 5 minutes stops working. Any ideas?
Steve, there are a several of basic things that can cause this problem.
1. Air filter is clogged. Turn electrical part of unit OFF, Remove and Clean Filter, if necessary.
2. Air intake obstruction. Look for air intake obstruction around the front of the heater.
3. If your unit is a flue-less heater, Oxygen Depletion Sensor (ODS) may be partially clogged with
dust, link or pet air. Clean Pilot Assembly using canned compressed air with a straw nozzle (like
you clean your computer with).
4. Gas pressure fluctuation to the heater. This will require a service call from an authorized Rinnai
Service Technician,
Hope this helped you to troubleshoot and solve the problem.
Jul 11, 2011 | Rinnai Heating & Cooling
How to clean the intake filter
I clean mine like this, unplug the fan and head outside, I use compressed air and a blow gun. I blow the air thru the intake and then backwards thru the front heating elements and repeat until you have clean air in both directions. I average about five times both directions and I am good for the year. I have made a practice of cleaning it out in the fall of each year.
Dec 26, 2010 | Lasko 5132 Ceramic Compact Heater
Cleaning filter
They are called security screwdrivers
or tamper resistant but you should find them here
http://www.amazon.com/Anytime-Tools-Security-Screwdriver-Reversible/dp/B000F7DWMQ
Jan 12, 2010 | Lasko 5530 Ceramic Compact Heater
Won't turn on. It gave me a beep when I plugged
Have you cleaned the filter that's on the back? This has happened to me, and I just took the filter out and cleaned it, and it worked fine after.
Dec 27, 2009 | Lasko 5130 Ceramic Compact Heater
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
Nov 30, 2009 | Lasko 5812 Heater
Lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Feb 15, 2009 | Lasko Ceramic Heater
Nov 29, 2008 | Lasko 5540 Ceramic Compact Heater
Heating & Cooling Logo
37 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
