Question about Mitutoyo Measuring Tools & Sensors
Mitutoyo digital caliper shows 0.000E - Mitutoyo Measuring Tools & Sensors
3 Suggested Answers
  • 9 Answers
SOURCE: 0-1 OD Digital Mic Mitutoyo hard to spin
You have a nice micrometer! Your problem could be caused too many different things. I would take the lead screw spindle off first and then clean both assemblies. (You can use W-D 40) this will allow you to clean the I.D. I do not know how much you understand how a micrometer works and would caution you not to adjust any of the adjustmants on the micrometer because it could end up out of calibration. I would be happy to take a look at it and free it up and calibrate it for you! I was the Manager and working Supervisor of a precision Tool Room for over 25 years and have quite a selection of parts. I would not want any compensation for the help and I would just ask that you include a prepaid return package. I am retired now and miss the work and I am constantly cleaning all my tools and I could do it then. Here is my e-mail address jedriscoll@rcn.com
Good luck, Jack
Posted on Aug 21, 2009
  • 3 Answers
SOURCE: mitutoyo digital caliper shows e--05 erro and will
Clean copper strips inside.
Posted on Dec 09, 2009
How do I change the battery in a mitutoyo digital caliper
Find the little battery compartment on the back. Slide it open, tap lightly against your hand to drop the battery out. Insert a correctly-rated new replacement battery in the same orientation as the original battery. Slide the cover back on. They make it about as simple as possible.
Jul 24, 2014 | Mitutoyo 500 171 20 Digital Caliper
How do I change the battery in a digimatic model # cd-6
In mitutoyo digital vernier battry inserted upper portion side by display you battry cover theire is an arrow mark downward release you will find battery in side remove it and put new one battery code Sr 44 you will from marketor in mall try it
Oct 17, 2012 | Mitutoyo Dial Calipers
HOW DO I GET A MANUAL TO LEARN HOW TO CHANGE BATTERY AND CALIBRATE?
The manual for this should be at the bottom of this page.
http://www.mitutoyo.co.uk/Mit/DisplayResources.jsp?category=instruction-manuals
The battery is just under a slide cover. You can zero it but to recalibrate you would have to send to a standards lab. The lab calibration would cost more than a new caliper so you really need to justify it. Basically if it is out of calibration just replace it, they are not really worth the money to recalibrate.
Apr 04, 2011 | Mitutoyo 500 171 20 Digital Caliper
I have a mitutoyo digital caliper model 500-230. i replaced the battery but when i pressed the on/zero button the display keeps running like its counting down and will not stop. The in/mm button seems to...
Sounds like the new battery you installed is no good. Is the display also dim? When the battery is low that is one of the results on the Mitutoyo. Do you have another battery to try in it?
Jan 08, 2011 | Mitutoyo 500 506 10 Electronic Digital...
I HAVE A MITUTOYO 6 INCH ELECTRONIC CALIPERS,MODEL # CD-6 CS. IT NO LONGER CAN SET ITSELF TO ZERO WHEN THE JAWS ARE CLOSED AND IN THE ZERO POSITION. PRESSING THE ZERO ABS CODE FOR 2 SECONDS AND THE...
The answers above by Kerry Littleton have nothing to do with our calipers. The answer above by Bob Pulver is well-intentioned but doesn't address the real issue.
The real issue is the ORIGIN button is little-used and a bit reluctant to "make". The solution is to use a blunt plastic probe to REALLY PUSH down the button and hold it. The caliper will reset to zero.
Dec 24, 2010 | Mitutoyo Dial Calipers
How do you rezero a 505-637 mitutoyo dial caliper
Fully close the caliper. The pointer should be pointing about straight up or close to it. Losen the knurled screw which is located on the circumference near the bottom. Now grab the dial and turn until the zero lines up with the needle. Re-tighten the knurled screw.
Dec 03, 2010 | Mitutoyo 0 150mm X .02mm Dial Caliper
How do I change the battery in my Mitutoyo digital?
The battery compartment is on the front of the instrument. The cover is round and has some symbols that resemble arrows pointing down. Slide the round cover down to access the battery.
Nov 05, 2009 | Mitutoyo 500 506 10 Electronic Digital...
Measuring Tools & Sensors Logo
24 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Doug Adams
Doug Adams
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
