Question about Brother PE770 Computerized Sewing Machine
I need a new bobbin case for PE-770
Part code XD1855-251
5 Suggested Answers
SOURCE: I have a brother pe-770
unwind it by hand onto another bobbin or empty spool
Posted on Nov 23, 2010
  • 458 Answers
SOURCE: I have a brother pe 770 and the bobbin will not
You need to sew the first stitch slowly. Lower the needle by hand and take up carefully. Pull the needle thread up and the bobbin thread should be caught in the formed loop and come with it. Pull them both to the back of the machine and sew.
Posted on Dec 15, 2010
  • 17 Answers
SOURCE: I have a Brother PE 770 and I can not get the
Just ask the experts if you do not want to bother. but if want to improve yourself, then do it carefully and patiently. would be fine.
Posted on Aug 14, 2011
  • 12 Answers
SOURCE: I have a Brother PE 770. All was well, fairly new
Most often, this problem is caused by a loose needle bar. When it has not been oiled, it become loose especially on the lower support. Usually, both needle bar and supports are ruined and the complete assembly need to be replaced.
So check if your needle bar is loose at the bottom. If so, the needle is not properly positionned with the hook and the thread cannot be catched.
See F05 speed sensor error. I explain there how to lubrificate the machine.
Posted on Jul 07, 2012
Brother pe 770 brand new with this error message F02 SS SW ON
Brand new? Take it back where you bought it. It is a defective unit.
Mar 01, 2017 | Brother PE-770 Embroidery Machine
Brother 780D will not feed thread through machine.
It is very important to have the bobbin case and the top tension both right. If the thread is getting stuck there is a problem. Always thread the top with the foot up. While threading make small pulls to make sure there isn't any places getting jammed. I've attached a rule document to help you to adjust the tension of the top and bottom.
May 20, 2015 | Brother PE-770 Embroidery Machine
Why does the bobbin keep showing up on top of the embroidery? I have changed the bobbin, I have rethreaded the top thread, I have changed the needle, I have cleaned the bobbin area. How else can the...
Loosen the top tension a little or tighten the bobbin tension ever so slightly. If that fails you can always color the bobbin threads with a magic marker the same color as the embroidery thread. You might go to Superior Thread's web site and try some prewound bobbins. They are worth their weight in gold. Dr. Bob knows all about all kinds of thread and is very good about answering questions. I think some of his Thread University videos are available too.
Jul 15, 2014 | Brother PE-770 Embroidery Machine
Troubleshooting Brother PE 770
Usually this is a tension problem. On mechanical machines, you'd adjust the dial, or possibly even the bobbin tension. But on a computer machine, I don't know how you set the upper tension, sorry to say.
Sometimes it can help to unthread and rethread a machine, and I don't know why it sometimes works, but it's a simple thing to try.
But if the upper tension isn't set correctly for the work being done or if the tension mechanism, however that's handled on a computer machine, isn't working correctly, this is what happens. Bird's nest is a good way to describe it.
Sometimes lint built up in the bobbin case can cause this symptom too, but I'd assume you keep this area clean. One reason I haven't yet invested in a computer machine is because problems like this often don't have such simple solutions as on the mechanical machines.
Jun 30, 2014 | Brother PE-770 Embroidery Machine
I have a Brother PE 770 and I can not get the bobbin case to go back in properly! Please help!
Aug 14, 2011 | Brother PE770 Computerized Sewing Machine
I have a brother pe 770 and the bobbin will not catch the thread. The thread will wrapped and tangled up around the bobbin case and bobbin, but will not catch the bobbin at all. I chcked the needle, it is...
Dec 14, 2010 | Brother PE770 Computerized Sewing Machine
I have a Brother PE 770. All was well, fairly new machine and whipped stitches out correctly. All of a sudden it is shredding the top thread and it almost seems the bobbin is not catching. Would this be...
here are some suggestions to try
it's may be the needle, it could be bent or blunt
it is possible that it could be the timing,,,, but first try changing the needle & try rethreading the
machine the top thread & bobbin also
make sure the bobbin is in the bobbin case correctly & that the bobbin case is correctly inserted into the machine correctly
check to see if there are any burrs on the needle plate
clean out from under the needle plate
also make sure the bobbin area is clean from lint or loose threads
Oct 18, 2010 | Brother PE770 Computerized Sewing Machine
Brother PE770 Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
