Question about Samsung V25 XVC 2800 Notebook
Samsung V25 notebook Tft failure
The power/data lead that runs the TFT screen has a multi pin plug attached. it plugs into a multi pin socket just to the left of the on/off button for the laptop (beneath the cooling fan cover) The multi pin plug has broken off the lead. I need to get hold of a new lead. where can I get one please.?
One arrived for me today from Romtrocincs.co.uk
Tel: 02084210101
Now just need to figure out how to get into the monitor case.
Russ
Posted on Dec 20, 2007
  • 432 Answers
We got your messsage and we're looking.
Posted on Jul 02, 2007
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
No signal found on Sharp LCD projector
test all power and data leads that attach to your hard drive the leads from your
(motherboard to your hard drive) Sata make sure they have dust free secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as a faulty fan lead can cause you problems a computer needs all of the power and data to travel through every working device and to
have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
if you remove the graphics card to clean the socket replace it
restart the computer the found new hardware wizard should activate
hope this helps
Jul 15, 2012 | Lenovo 3000 N100 0768 - Pentium Dual Core...
AOC 2036sa 20 Inch Monitor Tft Lcd red power led blinking
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Oct 25, 2011 | AOC 2036sa 20"TFT LCD Monitor
Need to know how to wire the power socket at back of v25
Have you determined the problem correctly?
The fault maybe the power adapter or the power plug that connects into the laptop's power socket rather than the power socket on the laptop.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. The power socket is soldered directly onto the motherboard, there is no wiring required.
If you cannot DIY then I suggest you get a quote first.
Dec 02, 2009 | Samsung V25 XVC 2800 Notebook
I have 3 colored vertical thin lines running vertical on my desk top screen, how do I get rid of them? thank you
Does it do this if you attach an external screen and view windows through the external screen. If not, then you have a fault with the TFT panel on the laptop. This would require a replacement TFT panel.
Oct 15, 2009 | Toshiba Satellite A60 Notebook
Hello ...i need to know which plugs go to what on the flat screen
All flat screens use a backlight (or sometimes 2 backlights). Going by the colours you mentioned, i'd asume it's those you are talking about.
If each of those 4 plugs is just 2 wires each, using small connections that can only fit one way round, then those are just your backlight wires, and you do not need to plug them into specific sockets, they are AC - avoid touching them while it's plugged in as they are hi-power. But you can plug them in any configuration. They will usually only reach as far as they need to - never pull or stretch them to get them to reach a different socket.
If your power light stays orange, it sounds like it may have more problems than that tho. It should come on, usually go green for a few seconds, they go orange when it finds no PC attached.
Typically, problems with TFT screens relate to either a complete mainboard failure, or more often, the 30 pin or 20 pin flat ribbon cable is not connecting properly. This is the part where the ribbon lays flat on the back of the actual screen. They are a stupid design, and prone to failure & random working even if the screen has not been moved or used. That is why they usually have so much strong securing tape over them - the manufacturers must have realised the flat connection fails too easily.
**This information is relevant to ALL TFT screens, including some laptop designs too**
May 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
15" tft LCD
any thing is possible but functionable probably not
Dec 26, 2007 | Systemax Pursuit 2130 Notebook
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
Dec 06, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Samsung V25 XVC 2800 Notebook Logo
130 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
