Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door will not close
Door can be closed if wall button is held in closed position
door will only come down a few inches with the remote
light bright on one safety sensor, the receiver sensor light is very dim, will not be brighter when aligned.
Took the received sensor off, laying on floor, wires still on it, the door works just fine
  • 504 Answers
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Posted on May 28, 2010
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
The door won't close with one click, I have to keep pushing the wall button to close the door, remote control won't work except for one inch movement down, the door will open with one click from both wall...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Apr 02, 2011 | Linear Ldo50 Residential Garage Door...
I have two craftsman door openers. They work great with pushbutton on wall, open and close ok. The door opens fine with remotes ( one handheld other homelink in car ) but will not close with remote. It...
If the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the lights on the sensors are both on and not flickering. Tweak them if necessary. If you cannot get both lights to come on you have bad sensors or the wiring to them.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener opens with remote but will not close with remote. will open with wall button but button must be held down until door touches floor to close
Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Nov 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Must hold wall unit to close garage door...
there is an error in the system. most likely The safety beams (mounted on the track near the floor) are out of alignment and the LED light should be blinking. The garage door opener will not let the door close if the beams are misaligned. Realign them and the LEDs on the beam or on the operator will stay on. you should be able close the door now with one push.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
195 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
