Question about Epson Artisan 1430 C11CB53201 Inkjet Printer - Wireless, 5760 x 1440 O
End of service reset code
Ink pad is at end of service and two light will be bliking
Lonewolf1038
  • 6 Answers
SOURCE: epson stylus photo r320 ink pad relacement
Here's 3 things you can do to get around this...depending if your printer is new and still under warranty or not (do NOT void your warranty!).
I have used all 3, but the third one was a lifesaver (AND money-saver!). About once a year I have to reset the printer using #2, but other than that....#3 is the greatest!!!
1. Try resetting it by, unplugging the power cord then while holding down the POWER STOP and MAINTENANCE buttons simultaneously while replugging the power cord caused a reset to zero on the counter. You will still have to replace the pads or redirect the waste ink tube to a receptacle on the outside of the printer, hope this helps?
2. If you go to inkjetprinterhelp.us there you will find the ssc service utility. Once you open the page click on the service utility and then choose the english version unless you can spk russian.If you then scroll to the bottom of the page and install the prog. Once you have installed the prog you will get the ssc utility logo in your bottom tray. Right click the icon and then select reset protection counter from the protection counter drop down. Once you have done this restart your computer and this should reset the system.
3. INSTALL AN EXTERNAL WASTE TANK and forget all about those gunky ink pads forever!
On the left rear of these printers is a small trapdoor held by a single screw.
Remove it, look inside (down and to your left) and you'll see the waste ink tube.
The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) I found the tube to be rather short....so I added an extension since I do not have room directly behind my printer for a container. I used the tubing you use with oxygen tanks or fish tank bubblers. They also make a little plastic connector so you can join the two together.
At this point, you're almost there.
All you need now is a suitable container for the waste ink, and I drilled a small hole in the trapdoor cover so you can put it back on without pinching the tube (or you could just leave it off.)
The container is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Any small container will work.
Make a hole in the lid (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever.
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I have a couple I can send you.
Posted on Jul 01, 2008
SOURCE: All lights flashing, Reset code wanted?
The answer to my problem was to download ssc service facility it not only resets my reset problem, it also resets inks as well. Download is free and i rate it first class. It covers many epson printers.
Posted on Dec 22, 2008
rioglen
  • 95 Answers
SOURCE: Epson R220 parts near end of life error
its a tweak with epson.... they have a counter there that intentionally stops it from working even through your printer is still in good condition.
there is an available driver that could correct that depending on the operating system you are using. i think if i maybe correct it only works with and o/s that is winxp.
the drivers name is inkpad reset utilty.
try to check the website www.epson.com/ipr for the inkpad reset utility
Posted on Sep 10, 2009
SOURCE: EPSON STYLUS T13 printer's ink
The printer's ink pads are at the end of their service life. Please contact Epson support. MODEL : EPSON STYLUS TX 121, SERIAL NO: MDSZO35514.
Posted on Jul 02, 2011
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Posted on Dec 19, 2012
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
A printer's ink pad is at the end of its service life.
You have to replace the Waste ink pad and reset the weste ink pad counter.
Mar 28, 2015 | Epson L210 - multifunction printer /...
Epson t60 printer ink pads are end of their service
This is not a question.
I suggest you google 'what is a question'
read up on it and then return with a plausible one.
Nov 25, 2014 | Epson Office Equipment & Supplies
Pm235 A printer's ink pad is at the end of its service life. Please contact Epson Support.
Is that a question or a statement?? Ink pads are replaceable and can be ordered from Epson or online.
Mar 06, 2014 | Epson Printer
Printer's ink pads are nearing the end of their service life.
The printer's ink pads are nearing the end of their service life. Please contact Epson support.
Dec 04, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
Nov 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Apr 26, 2011 | Epson Printer
I switch my CX6600 on but all I get is the exclamation mark light up. |The displau says that par6ts are at the end of their service life. No warning! Anyone help please
That message indicates that the porous waste ink pads inside your product are near the end of their service life. Epson recommends replacing the printer, but if you want to continue using it, I'd suggest having the printer serviced at an Epson Customer Care Center. You may also be able to have the ink pads replaced by an independent service provider and use the Ink Pad Reset Utility to reset the Ink Pad Counter to continue using the printer. However, replacement of ink pads is relatively expensive and may not be a good investment for lower cost printers because the printers' other components also may be near the end of usable life. Hope that helps!
Mar 03, 2011 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus C66 PRINTER KEEPS ON FLASHING RED LIGHTS ON THE INK BUTTON AND PAPER BUTTON
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
Epson Artisan 1430 C11CB53201 Inkjet Printer - Wireless, 5760 x 1440 O Logo
271 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
