Question about Whirlpool Heating & Cooling
I need english manual for air conditioner like WA6062Q
How do I set thermometer so heat stops when temperature is reached and comes on when it drops?
Therinnaiguy
  • 1420 Answers
SOURCE: Airflow
Go to www.mrslim.com. Look under the tab for library. Ib there you will find the troubleshooting guide for this model. Make sure the remote is set for cool and make sure the fan setting is not on automatic.
Posted on Aug 30, 2007
pierre1811
  • 144 Answers
SOURCE: Electric furnace runs but won't shut off on heat setting
I would insist that Sears either have a Senior tech come out and fix it or return it to the state it was prior to them touching. Then call some one else. Have them involve the Goodman rep in your area.
Posted on Jan 20, 2009
pierre1811
  • 144 Answers
SOURCE: electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
ronaldo_ross
  • 1056 Answers
SOURCE: I have a Concord air conditioner, central heat and
You can try getting it serviced. Vacuuming the system and charging it up with new refrigerant, as well as replacing the reciever drier, will help tweak your AC system. This is no guarantee though. It might be able to bring the temp in your house down several more degrees. Also try cleaning the condenser outside. You can spray it with water to clean off dirt which block air from passing through. This hepls a bit and you can do it yourself.
Posted on Jun 28, 2009
luker711
  • 91 Answers
SOURCE: My home's Air Conditioner shuts off and on until reach temperatur
You have some issues that probably need to be addressed by a Certified Tech asap. There's an off chance that it could be just thermostat related. If you feel confident on doing what I'm about to instruct go ahead and try it.If you turn off electricity to your unit(should be marked as A|C or furnace or the like if you have the unit on and turn off at the panel it's easier to locate) you can take the cover off your thermostat and you will find various wires. Unscrew the R, Y, and G wires(if they;re not colored red yellow green make a diagram as to which goes where) and twist them together, Then turn electric back onto unit. If the unit runs normally as it should, then you have a thermostat problem and need to get a new one right away. Remember you unit is worth $2,000 to $6000 don't let and electrical malfunction compromise the value, if it.s not the thermostat get someone qualified to look at it. Leave it off til they get there. Good Luck
Posted on Jul 16, 2009
What is difference between on an auto on thermostate
I'm not sure exactly how this applies specifically in a car, but on a home heating and cooling (air conditioning) thermostat, it is often associated with the fan or blower setting.
If for a system fan:
"Auto On" setting in a heating / cooling system would start the fan when the temperature climbed above or dropped below the setting you on the thermostat and start the heat or cooling source. Once the thermometer indicates the desired temperature had been reached, the heating / cooling source would be stopped and the fan would turn off.
"On" would run the fan all the time, regardless if the thermostat tired to start the heat or cooling source. This would result in constant circulation of the air in the space(s) and tend to keep warm or cool spots (rooms) from being created.
Nov 30, 2015 | Cars & Trucks
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
Series 48000 with heat pump we don't want this to run all the time will the heat shut off when it reaches a certain temp also if the power goes out does it come back on automatic we want to heat our place...
Not sure about your particular make and model, but air conditioners are designed to work with a thermostat to control the functions. A properly functioning thermostat will stop the compressor when the set space temperature is satisfied. When the space temperature falls below (heating) the set temperature, the thermostat should turn it back on. In the event of power failure, an electronic thermostat probably will not operate at the previous set temperature when power is restored, but maybe at a higher temperature (but will work).
Dec 05, 2013 | Coleman Mach 15 Air Conditioner
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
Aux keeps coming on on regular heat is there something wrong with heat
See if it happens only when your temperature of the room is more than 3 degrees of your setpoint temperature. Since you have a heat pump, the auxiliary (electric heat strips) is use for backup of the heat pump when it can't keep up. The heat pump will run by itself if it can maintain temperature within a couple degrees. If it is too cold outside to handle the load or you set the temperature more than 2 degrees past room temperature, the auxiliary will turn on. The thermostat has a memory of how long it takes to reach desired temperature. If it goes into auxiliary mode trying to satisfy setpoint during the last call for heat, it will start the next call for heat in both aux & heat pump mode until the thermostats algorithm (timed program) allows only the heat pump to run. Not sure if you have an air to air, or geothermal heat pump. The outside air temperature will affect only the air to air system ie. when the temps drop outside, the heat coming out of your vents will be cooler...the air to air systems drops efficiency when the outdoor air drops.
Nov 08, 2013 | Honeywell TH3210D1004 PRO 3000...
I have a Competence 52081 double oven. Ity has
Thermostat may need adjusting OR air may be entering the oven causing the problem
Sep 01, 2009 | Ovens
Electric furnace won't shut off
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Airflow
Aug 13, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Jul 10, 2007 | Sharp CV-P09FX Air Conditioner
Heating & Cooling Logo
43 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
