Question about Logitech X-240 Computer Speakers
Only one speaker works right
I can only get good sound out of one speaker, and when i adjust the volume it cracks and volume goes up and down
  • 238 Answers
Hi, install audio codec for that matter. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
*Drop me a comment and i will assist you. I hope this will fix your problem.
Best regards
Posted on Jan 21, 2009
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
Speakers were working,then i pressed something to see if was gonna sound different and now i cant find my way back to what it was...sound is coming from the computer to the tv,,but external speakers have...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope it helps
Sep 22, 2011 | Logitech X-230 Computer Speakers
I had my harddrive reformatted on my desk top pc and now my altec lansing avs200 speakers wont work on my computer
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you
Jul 25, 2011 | Altec Lansing Multimedia Computer Speakers
Speakers are not loud
Hi ,
down on the very right side of your task bar is a icon of a speaker , click on that and it will allow you to adjust the sound level............let me know if this works ,,,,,,,,,,,,,Roy
Jul 21, 2011 | HP Audio Players & Recorders
My compaq 511 laptop's speaker doesn't work? What should i do?
also
Jul 19, 2011 | Compaq Audio Players & Recorders
Radio on 2008 dodge nitro stops working it goes out for a while then comes back on. no sound even when turning the volume up and down. it makes a loud popping noise and goes out.
Im having the same problem! No pop, just a hum, and my volume dial won't adjust. Like the actual dial isn't working. I can't use radio, cd, or aux. Silence SUCKS.
May 31, 2011 | 2008 Dodge Nitro
Change the volym
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Mar 01, 2011 | JBL CREATURE II Computer Speakers
I cant get my NEC speaker to work for my computer. Is there a specific plug in the monitor that it goes into? Or do you need a software?
click start control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Jan 06, 2011 | NEC Orca Jazz Speakers Assembly Kit...
Problem with right channel on vintage Denon PMA-501 amplifier. No sound... Any advice? Thanks...
Good day sir/maam, to verify if the right channel is the problem, swap the speakers to confirm. Assuming that the right channel is the problem, set the balance control to the right (or simply disconnect the left speaker) and place you ear near the problem right speaker. Adjust the volume control up and down several times. you should hear a soft hiss that goes up and down also. this comfirm that the power amplifier stage is good. the problem is anywhere from the tuner/tape/cd/switch or jack. If you dont hear the hiss sound then the power amplifier is the problem. in both cases, you may need to bring it to a service center. hope this helps.
Jul 18, 2009 | Audio Players & Recorders
Logitech X-240 Computer Speakers Logo
151 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
