Question about Maytag Neptune MCE8000AY Electric Dryer
How do I remove the lint trap holder to clean out the lint inside
My dryer is a Maytag model #HYE3657AYW.
I want to remove the lint trap holder to clean out lint from inside, but it seems as though something is stoping it from coming out. I removed the front 2 screws and I can slide it back just not all the way out.
  • Anonymous Mar 02, 2009
    I am having the same problem, did you find an answer anywhere?
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Posted on Feb 11, 2009
  • waynechch Dec 13, 2010
    The 2 screws on the front look like they will allow you to lift out the lint filter assy but they actually release it so it can be removed from the nside once you get the front panel off.
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
Lint trap hole full of lint
caused by a back up of debris ,, remove the vent tube, and clean it throughly , including the vent cap outside, check for damage to the flap inside of it, if it has one, then remove the back of your machine, and remove the vent tube that goes from the blower fan to the vent ( lint) trap, clean out all of that , and any build up of lint in the machine, ( unplug it first )
Jul 04, 2011 | Maytag Dryers
How do you take the Lint Filter holder out of Dryer?
There should be a small trap door located on the top of your dryer. Open the trap door and pull out the filter cartridge. Carefully clean the screen and place back into the compartment.
Jan 25, 2010 | Maytag Dryers
I have a maytag model HYE3657Ayw how can I open it up to clean lint inside the cabinet
first pull it away from the wall, then clean out the lint from the vent, then you will need to pull the front panel off, you should find 2 screws inside the door opening, and then you will need to pop loose the tabs from the bottom
Jul 10, 2009 | Maytag Neptune MCE8000AY Electric Dryer
It is taking 3 full cycles to dry my small loads on my Maytag Performa PYE2300AYW. I have cleaned lint tray and trap. I need to clean the lint from the inside of my dryer - How do I do this?
The main area that you have to clean is the pipe leading from the back of your dryer to outdoors. Pull your dryer away from the wall. Unplug it. Unfasten the vent pipe. Now look into the back of the dryer exhaust and remove any lint you see there then look into the vent pipe and remove any lint. Finally go outdoors and remove any lint you see in the pipe or the pipe grill/cover.
Jun 04, 2009 | Maytag PYE2300AY Electric Dryer
Lint trap
http://www.pcappliancerepair.com/model-display.php This will show you how your dryer is put together. The lint has gone directly to the fan, where it could affect fan performance. You would have to remove the front off the dryer, and the cover off the fan area. It's not a bad idea to clean this area once in a while.
May 11, 2009 | Maytag Neptune MDE4000 Electric Dryer
Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
Dec 13, 2008 | Maytag PYE2200 Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
1,840 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
