Question about Aiwa Audio Players & Recorders
I have an old Aiwa NSX-V150M Compact Disc Stereo System. I cannot load CD's into the unit. Pressing the "Load" button causes the internal mechanism to cycle up and down 5 or 6 spaces and then a "CHECK" message appears. The load tray never opens.
Hi! I also have an (old) NSX-V150M that does nearly the same, I suggest two problems on mine: 1) maybe the laser assy has to be changed because it doesn't detect the actual CD anymore and skips to the next one. 2) there is a tiny limiting switch on the moving platform that seems defective, or the rubber belt (?) is too stretched, so that it doesn't detect when the CD is in place from the changer. Then the unit starts again "CHECK"ing, as when the memorized list of CDs doesn't match the detected list of CDs. For the first one, maybe the Sony KSS210 or KSS213 spare part could be used, not sure of it. For the limiting switch, I have glued a match to keep it in place to keep the CD part quiet. Result: no more CD playing for now, but the unit doesn't "CHECK" anymore, and tuner and amplifier still work great. Need to look inside one of these days.
Posted on Jan 14, 2013
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
SOURCE: JVC Stereo won't open cd tray
take off the cover and get whatevers jamming it out mine did the same thing
Posted on Jul 30, 2008
  • 3422 Answers
SOURCE: RCA RS2025 Bookshelf Stereo CD Player Hangs Up
Ok,
Look for a reset button at the back or may be at the front head of the cd changer.It is a very small 1mm hole.If you find it insert a paperclip in it,press and hold it for 1 min.This will reset the unit.If you still face the problem then just unplug all the cords of the changer for 1 hour and then plug it back in.
Posted on Sep 04, 2008
SOURCE: How to play CD on Aiwa NSX-3500 (part of CX-N3500U) w/o remote control?
I thought that I had the same problem. I then discovered that when I put 3 CD's in it started up on it's own. If you push the demo button you can see how it's supposed to light up the number of tracks in a square on the right of the display. It wasn't doing that until I put in all 3. Then it started up and I was able to use the disc 1, 2 & 3 buttons to change from 1 CD to the next and I used the Up and Down buttons to change songs and the play button above the tape deck is multi-functional. Hope this helps.
Posted on Apr 27, 2009
Aiwa NSX-A888 Stereo System CD Player
Cleaner disks are a waste. You're better off cleaning the lens with a cotton swab and rubbing alcohol
Apr 14, 2013 | Aiwa NSX-A888 CD Shelf System
MY STEREO KEEPS TURNING ON AT 1 O'CLOCK EVER NIGHT???
Check with AIWA they might be able to supply the Operating instructions free. Some have them as a PDF on the website.
Dec 18, 2012 | Audio Players & Recorders
Aiwa NSX-A-J800 Manual
Retrevo has the manual for the Aiwa NSX-AJ800 Stereo System here: http://www.retrevo.com/support/Aiwa-NSX-AJ800-manual/id/1076dj383/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
(note you will need Adobe Reader or a similar program to read the file)
Dec 23, 2011 | Aiwa NSX-DS55 CD Shelf System
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
JaHa
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
Open/close doesn't work
When you press Eject CD button, do you see CD display blinks as if its preparing to be ejected? If its true then eject switch is working and cd mechanism is stuck, requires service. Also check loading belt in mechanism.
And if unit shows no response on pressing CD Eject button then switch is bad, replace it.
Jun 30, 2009 | Aiwa NSX-A115 Shelf System
My Compact Disc Stereo System NSX-AJ50 is tripping off every time I turn it on. Henry dulcerito@live.com Thanks.
One or more of the output transistors has failed or you have a bad speaker. Try disconnecting both speakers and turning on the unit. If it still shuts down, then the transistors are likely to be defective. These can be replaced for about $15-$25 plus labor at any service shop that handles audio gear.
Dan
Feb 20, 2009 | Aiwa Audio Players & Recorders
Aiwa Stereo System NSX-F9
insert CD lens cleaner first, then try to load audio CD if do not work change the lens
Nov 24, 2007 | Audio Players & Recorders
191 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
