Question about Compaq Presario Notebook
Computer will not boot up
I have a Compaq Persario V5000. When i turn the computer on, the compaq logo comes up and then a flashing (-) shows in the left corner. The computer will not do anything else. I have the recovery disk, but when i put the disk in, it will not doing anything. Can someone help
  • chessyang May 11, 2010
    can you load the bios?
  • 41 Answers
Theres some information on how to do the recovery on your computer.
http://support.thetechguys.com/layout.aspx?ID={08478b5e-96b4-4e92-9e3a-61810647032b}&CatID={37257f71-f92f-4574-b3be-f0f6705594b4}
Posted on Jan 21, 2009
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
I have a compaq presario computer using a compaq monitor. I have a Gateway HX2000 LCD flat screen monitor (year 2009) that I want to us instead of my compaq monitor. I have disconnected the compaq monitor...
I'm guessing the different monitors are different sizes? The only thing a driver for a monitor will do will tell the computer the max resolution that the monitor will be able to go up to. However most 90% of monitors can use the built in windows driver without issues. Your best bet is going to be to change the resolution on the monitor. To do this you can either hook up the old monitor, lower the resolution, and then plug in the other monitor. Or you can boot the computer into VGA low resolution mode by pressing F8 as the computer starts up and selecting that option. From there you can lower the resolution, and then put it at something more desirable with the new monitor.
The other possibility being your Gateway monitor is actually malfunctioning and you just happened to hook up a bad monitor.
Mar 27, 2011 | Computers & Internet
I don't have anything on the screen on my presario v5000. When i power it on, i see the word compaq but it's very very very pale. I think it could be the inverter. Can you confirm or help me. Yvan
Hi Yvan!
Even if the inverter is the problem, it should go past the Compaq logo, it should still boot to windows as normally as it should.
If it boots to Windows, it's an inverter problem, if not, then it's something else.
Best Regards,
Ben
Mar 21, 2011 | HP Compaq Presario V5000Z Notebook
Have a gateway Mt3708 it started turning off on its own now I have no screen. I had gotten message reading as follows: YUKON Pxe V4.17.8.1 (alpa) (20060116) (C) copyright 2003-2006 Marvell (R) all rights...
when the logo comes on, press the "tab" key. It should turn the logo off and show you what the computer is doing. This may help:
THIS IS FOR HP AND COMPAQ USERS (it might help others as well)
i had the same problem with my compaq preasrio v6000.
ALL U HAVE TO DO IS
1- START UP UP UR COMPUTER AND PRESS F10
2-GO TO DIAGNOSTICS
3-RUN A HARD DISK TEST
IF IT PASSES THEN YOU JUST NEED TO RE-INSTALL TO YOUR OPERATING SYSTEM
IF NOT YOU WILL HAVE TO CHANGE YOUR HARD DISK.
Or try this:
Go into the BIOS.. Go into the BOOT options.. and hit Shift+1 to disable the Realtek boot option.. pop in the disk you want to boot from.. and make sure you set your boot options to CD-Rom and then HDD.. and just wait.. be patient.. and the blue screen (for booting) will show up! :)
Mar 15, 2010 | Computers & Internet
My computer is compaq persario sr1730il not getting its driver
let ur comp model be that what is ur mother board model number? and brand company name?
sure will help out
Mar 01, 2010 | Compaq Computers & Internet
Got a v5000 laptop compaq it dont boot up ive checked hard drive and memory any i ideas
Leave the computer off for a long while...i got a new computer too and it did that but i left it alone for a long while and it started working again.
Feb 09, 2010 | Compaq Presario 5000 PC Desktop
Compaq presario v5000
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
This series of compaq laptops have an issue with current draw on the mainboard, you will need to send it to compaq for a new mainboard.
Feb 18, 2008 | HP Compaq Presario V5000Z Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Compaq Presario Notebook Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
