Question about Teac AG-V2050
Teac v2050 direct tv remote - Teac AG-V2050
Need help tuning my teac lcd v1955hd tv with out remote as just moved and lost controller and kids need there tv
It can't be done, you have 2 choices. But a genuine TEAC remote or a get a set top box
Oct 06, 2017 | Teac Televison & Video
Looking for a TEAC UR-417 Remote control
go e-bay and in the want to buy search type in remote control for teac ur -417 enter and see what is available
contact teac direct on their web site and see if one is still available
remember that manufacturers seldom change the frequencies that remotes work on so even though the specifics may be a bit different , it probably would still work
Sep 25, 2015 | Teac Audio Players & Recorders
I have a teac Tv which I wish to have repaired under warranty who should i contact at least initially for technical help?
You can call (800) 447-8322 to find a Teac authorized service center in your area. If you are unable to find a repair person in your area you can call the company directly at (323) 726-0303. http://www.teac.com/support/warranty
Sep 07, 2015 | Teac Televison & Video
Cant get sound to play through speakers? proper way to hook up?
Do you mean HDMI from Monster, if you do ensure that the cable is connected securely to the correct port. HDMI cables rely on both the devices for sending and receiving. Nothing will happen until both devices send the opposite signal. Hope it works for you!
Apr 29, 2013 | Teac AG-V2050
Manual
Have you got the wires connected to the correct voltage D/C outputs.
What interface are you using to send the sound ( If you are using one ) If you are ensure that you are on the correct channel and the the device is sending sound. (This may sound silly but make sure you have the volume up and that you don't have headphone attached, It happens to the best of us)
I have a audiosonic kgr1 remote and need the set up instructions and teac tv codes
You're in luck - try each of these 4 digit codes for TEAC TV:
1627 1085 1152 1154 1165 1168 1171 1181 1183 1193 1283
Nov 30, 2009 | Televison & Video
Front speakers cut out
Funny you asked! I just got this receiver today, and its the first problem i had. Its the speaker wiring quality. I had thicker better quality wires in center channel speaker and audio was fine. Cheaper thinner on front and kept cutting out on 3 or 4 voulume level. I switched wires just to test and it never cut out again. Audio was fine.Try better thicker wires and u should b alright.
Aug 16, 2007 | Teac AG-V2050
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
