Question about Velocity Micro Cruz Reader R101 Tablet PC
My Cruz T410 will not charge or turn on. How can I fix it? I have only had it for 9 months.
How to Reset the Velocity Cruz Tablet?
A.) With the device powered off, press and hold the volume up button (keep holding), then press and hold the power button at the same time. Keep holding both buttons. The Cruz logo will appear, you may then release the buttons. Then the Android robot and software package icons will appear on the screen.
B.) The moment you see the Android robot, you will need to access the System Recovery menu by pressing and holding the Power button, then tap the volume up button once, releasing both. This is in the opposite order of the sequence in Step A.
NOTE: The volume up button on the T408 is toward the power button, while the volume up button on the T410 is away from the power button.
C.)
In the System Recovery menu, use the volume toggle to navigate up and down through the menu and hightlight your selection. Use the power button to activate your selection. Select the option that corresponds to clearing cache and data. Once completed, select the option to reboot your device.
Oct 17, 2016 | Android Tablets & eReaders
How do I get my tablet to come on?
Try a faster charger.
If you're only using a USB charger, it might not deliver enough current. Use a genuine 'travel charger' from the original manufacturer to charge at a higher current than the trickle charge coming from your PC or generic charger.
Your other option is to leave it plugged in for a good 24 hours or more... without using it. Worked for me.
Mar 03, 2015 | Velocity Micro Cruz T410 10in Android...
My cruz wont turn on after i reset it?
Most tablets are still in the factory settings so if u have a professional to look at it he might be able to turn it on and u could then have him look at the charge thing.
Jan 20, 2014 | Velocity Micro Cruz Reader R101 Tablet PC
It wont turn on
When a tablet is completely dead you will need to charge it from a wall plug and not a computer. Also try holding the power button for 20 seconds, it is possibly frozen.
Feb 01, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
Velocity micro cruz, cant access webcam
Not sure which model you have but if by chance you have the T410 model, instructions for using the camera can be found on page 27 of the manual at the following link. This looks like a very nice device!
http://s3.velocitymicro.com/vmcruz/T410/manual/Cruz_Tablet_T410_User_Guide.pdf
Jul 20, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
I turned the Cruz Reader off and I can not get it to turn back on. I tried to charge it but no light will come on. Any suggestions?
Taken from Velocity Micro Support Center:
What should I do if my Cruz device will not turn on?
If your Cruz device will not turn on or freezes, follow the steps below to resolve this:
  • Locate the Cruz RESET location between the Power Button and mini-USB port.
  • Using the straightened end of a small paperclip, insert it perpendicularly into the RESET hole and hold for 5 seconds.
  • Turn on your Cruz
If the steps above do not allow you to power on again, then continue with the steps below:
  • Remove the Cruz from the charger and eject the External SD card.
  • Place the Cruz face down on the desk, starting at the External SD slot, pull off the back cover of your Cruz.
  • In the lower left corner of the back of your Cruz, locate the battery power cable. Unplug the cable and replug it again.
  • Return the back cover to your Cruz and snap it into place.
  • Re-insert your External SD card and power on your Cruz.
Jan 02, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Velocity Micro Cruz Reader R101 Tablet PC Logo
124 people viewed this question
Top Velocity Tablets & eReaders Experts
steve morris
steve morris
fred capra
fred capra
Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
