Question about Watches
How to put the exact time on
The watch is not letting me have the exact time here is the bar code 82924tc 1295-10 cr2016 module.
2 Suggested Answers
gemineye61
  • 831 Answers
SOURCE: i don't know how to
Thank you for contacting FIxYa.
I dont know anything about this watch, Is it a digital? If so, here are generic instructions for digital watches that might help.
CHANGING DIGITAL TIME:
  • Examine your watch. Attempt to find its "Mode" button; nearly every digital watch has one. The various modes might include "Date," "Alarm" and "Stopwatch" among others. Repeatedly press "Mode" to cycle through the modes available on your watch until you have it in the mode that displays the current time.
  • 2 Locate the button that allows you to adjust the settings on your watch; this button could be labeled "Set" or "Adjust." Once you've found this button, press it in and hold it. After a few moments, the time display should begin to flash.
  • 3 Select either minutes or hours as the aspect of the time you'd like to adjust. Press the "Mode" key to cycle through your options; each element should begin to flash as it's selected.
  • 4 Press a button to adjust the time element you've selected; the button for doing this will vary from watch to watch. If there are up and down arrows on your watch, use them to increase or decrease the number. A button labeled as another function could serve this purpose too; trying pressing the various buttons on your watch to discover the correct one to adjust the time.
  • 5 Move on to the next element you want to adjust, such as minutes or the date, by pressing the "Mode" display.
  • 6 Press the "Set" button to finalize the new time on your watch. You'll know that the time has been set when the numbers stop flashing.
  • Best regards. Jewel
    Posted on Sep 14, 2010
    What's the band size for a cr2016 Timex indiglo? Also says wr 30 m.
    these are not the model number , CR2016 is the lithium battery number and the WR30 is water resistance 30 meters.
    you will need to send the watch off to Timex csd@timex.com
    May 09, 2017 | Timex Watches
    Do I reuse 2 batteries for my Umbro chrono watch?
    Normally the Umbro Chronograph watches having analog and digital clock works on single battery. When u put the battery inside ur digital is working fine but some times for analog hands do not move due to the loose button which is used to move the watch hands. So pull it out again and insert it agin gently till tick sound comes and u r good to go.
    Let me know if ur watch is working successfully:)
    Jan 27, 2017 | The Watches
    How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
    Timex Triathlon Ironman Watch Battery Change - YouTube
    ? 2:44
    https://www.youtube.com/watch?v=x_C7VsE8Kks
    Jun 26, 2015 - Uploaded by Lin Le
    Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
    How To Change CR2016 Battery In Indiligo Timex Watch
    www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
    Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
    Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
    How do I change batteries on a M.Z. Berger AW 213 watch
    I know it's been a while since you posted this question, but I just had to do this with mine after it was lost in a drawer for a few years, and I had no luck googling so I had to figure it out for myself.
    First, you have to remove the band, but you only need to do this on one end, not both. I did this by twisting the watch body around while holding the cloth/leather portion of the band still, letting the elastic part twist around with the watch body. Then, just use a fingernail to pull on the ridges on one end of one of the pins that are holding the band on; both ends are spring-loaded, so it doesn't matter which. Twist the watch body back around, and you'll now be able to flip it over to expose the back.
    Now, take a thin, strong blade (I used a butterknife) and pry off the back plate. There's a tab on the upper right edge of the back plate to make this much easier. Since it probably came off in the process, place the rubber sealant ring back around the edge of the backplate.
    Once you have the back plate off, there's a thin metal piece covering the battery that's held on with one screw. Remove that with an eyeglass screwdriver or any other similarly-sized Phillips-head screwdriver. There's just a small tab holding the metal piece in place on the other side, so just flip the metal piece up a bit and pull it out. You can now take the battery (a CR2016 3-volt watch battery) right out.
    But wait, what's this? Beneath that battery, separated by a small plastic insert, is another, smaller one, a 377/376 1.55-volt watch battery. The 377/376 powers the analog movement, while the CR2016 powers all the digital stuff and the backlight.
    Replace both batteries, making sure to place the plastic insert back on top of the 377/376 before putting the CR2016 back in, and follow the steps in reverse to put the watch back together. You may have some difficulty getting the back plate back on, but I just pressed one side in and held it while I tapped the other side down with my fist.
    Apr 28, 2014 | Bulova Watch
    Elgin watch battery
    The 377 battery is located behind the CR2016 battery. You will have to completely remove the motherboard to change out this battery that runs the analog portion of the watch.
    Apr 12, 2014 | Elgin Watches
    Timex expedition indiglo wr50
    The battery is a CR2016 as noted in the description. Hard to find these days.
    Aug 31, 2017 | Watches
    I have a Timex I bought in 2007 on the back of the watch it says CR 2016 cell and WR 100m. The time started to catch on a certain time and stopped the date from working properly, I need to know how to...
    You should probably replace the battery using a new CR2016 battery. Let the watch set a while without the battery to help it reset. WR 100m just means the watch is "Water Resistant to 100 Meters". Then use the following info.
    Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
    Complete Timex link site:
    http://www.timex.com/info/Product_Instruction_Guides_Downloads
    Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
    If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
    I hope this helps you. Thanks, Bill
    Sep 01, 2010 | Watches
    How to release the battery clip on Casio Databank DBC-1500?
    I would get it repaired by a Casio technician it will save a lot of headache. www.casiowatchrepair.com
    Feb 24, 2009 | Casio DBC1501 Wrist Watch
    Which watch battery do I use?
    There are lots of different size button batteries for watches. I work in a clock shop where we change batteries in watches and I have had people bring the watches into me without batteries and it is really a guessing game. A lot of watches take a #377 battery. You can try that or take it to a place that changes watch batteries and let them figure it out.
    Mar 08, 2008 | Watches
    Adjusting my timex expedition cr2016
    nike T20 lap digital sport watch? Older model. cannot adjust time, date, etc. Know where to get instructions?
    Sep 25, 2007 | Nike Super WR0064405 Wrist Watch
    Watches Logo
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
