I have a Janome MC11000 Embroidery Machine. It is only 4 months. I am having a constant thread breakage problem.
    Genius:
  • 1,102 Answers
Honestly if it has always done this and it's only 4 months i would return it.
they are expensive machines so don't waste your money return it
Posted on Jan 21, 2009
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
Computer saying thread broken
Bad board, dirty thread sensor, thread sensor out of alignment are my first three guesses.
Jan 04, 2014 | Janome Clothsetter 860401005 Extension...
Janome MC11000 how do you realign your embroidery unit. When doing applique the satin stitches do not cover the tackdown stitches. I've tried several designs, all by quality digitizers and all the...
P, attern is from monster knits for little monsters. I'm attempting to do the little piggy on page 24. It a pull over hat with a neck ruff.
Dec 05, 2013 | Sewing Machines
I want to use a metallic thread for decorative sewing but the thread keeps breaking , can anyone help. I am new to the machine & embroidery thread
Three things to check:
1.You need to use a needle specifically made for metallic thread. I believe the eye of the needle is square and the thread will pass through it easier, and will not be shredded which can be a cause of breaking.
2. Be sure to check your tension to make sure it is not too tight on the top. Test your stitches, checking both top and bottom tension.
3. The thread should come off the spool straight, not twisting. The thread cone should be standing up straight and the spool should twirl to release the thread. If the spool is not moving and the thread unwinds from the stationary spool, then the thread is twisting and that can cause the breakage as well.
Nov 27, 2010 | Janome Memory Craft 9000 Computerized...
I want to sell my 1991 New Home memory Craft 8000 sewing machine
A good place to see what machines are selling for is Ebay. That's where I sold a sewing machine and an embroidery machine.
It helps to know your product and machine embroidery lingo.
What are cassettes? Floppy disks? These make the machine borderline obsolete.
Memory cards are still around, but most EM now have USB connectivity or USB flash drives.
Satin thread? Embroidery machines use Rayon or Polyester embroidery thread.
Having had the machine recently serviced is also a plus.
Mar 19, 2010 | Janome Memory Craft 9000 Computerized...
Singer CE-150: Constant error messages, thread breakage, etc.
Check the sensor at the top of the machine. It is where the thread passes through the plastic "u-turn". Check to see if the wheel turns when you pull the thread through the machine. The wheel has a red marking on it. If the wheel isn't turning when you pull the thread, it may not be sensing the threading correctly.
I hope this helps. God bless you!
Mar 09, 2010 | Singer CE-100 Futura Computerized Sewing...
Janome MC11000 - my bobbin case becomes dislodged
My bobbin case was jumping all the time...had it in for repairs and would bring it home and even though the tech had attached a test sew piece with different colored bobbin and top thread I could not get it to sew without the bobbin jumping. I thought that he had lied about that being sewn on this machine...finally, I found that you should start with plenty of thread in your hand when threading machine...so that once you feel it click into the tension...DO NOT PULL the thread, it pops it out of the tensioner...just loosely thread and hold tension with your thumb and forefinger while using the needle threader.
Feb 14, 2010 | Janome Memory Craft 10000
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
