Question about Bosch SHX2AR55UC 24" Bar Handle Dishwasher - Stainless Steel
I need to know how to turn off the finished cycle alarm on my Bosch Ascenta Series dishwasher, model # SHX2AR55UC?
SOURCE: Bosch Logixx dishwasher alarm
I have found the operating manual online (see link to below off Bosch site) which explains how to do this - looks a bit fiddly by twisting dial and press/hold different buttons. Too complex to repeat in detail here so check out the website:
http://www.boschappliances.com.au/content.asp?document_id=430&category_id=86
from the above page (which I know is not the same model)
- follow the User Manual link
- enter the correct model number (mine is WAS32466)
- select the operating manual instructions (installation manual may also be given)
- see section on Individual Settings / Signal.
Sorted.
Andrew
Posted on Jan 25, 2009
PapaSmurerf
  • 3 Answers
SOURCE: Bosch built in dishwasher shu4302uc
There are no adjustments for cycle timing. What does affect timing is temperature of the water coming into the DW. The hotter your supply water, the shorter the time to cycle, BUT if your water is too hot, the cycle time may become too short to light the NSF 'Sanitize' indicator. But since the cycle is taking so long, this is an indication that the DW's water heater is not heating the water hot enough to advance the countdown timer in a timely manner. The control logic is waiting for the temp to come up to an appropriate level to ensure adequate washing, rinsing or drying times. Likely your display is showing '1' for a long time as a symptom of this problem, as well.  - This link http://www.applianceaid.com/boschDW.html has procedures to run self-tests on various Bosch models. I suspect that you can confirm a 'heater fault' on your unit by running the self-test.  - This problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. If you have a Torx driver, soldering iron & bit of solder, you can effect a repair yourself in about an hour. Otherwise, a replacement control board is required.
If you'd like to attempt replacing the control board yourself, refer to this link for part & DIY information. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
- Else, place a service call to the tech of your choice.
Posted on Mar 01, 2009
  • 98 Answers
SOURCE: Bosch SHX33A runs continuously. Never finishes cycle.
I have a guide here to walk you through the process of clearing the drain system. You most likely have a clog somewhere and the dishwasher can't proceed because it would cause it to flood.
Posted on Jul 27, 2009
  • 457 Answers
SOURCE: the dishwasher is stuck in the drain cycle Bosch SHX46A
you have a leak,or the something has the float stuck in the open position. when water gets in the base the float raises and the uni automatically drain until the water is out of base. if this helps post a 4 thumbs up post
Posted on Feb 28, 2010
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Bosch dishwasher door pops open during cycle
Latch needs adjustment or replacement.
Jul 07, 2015 | Bosch Dishwashers
My bosch dishwasher is stuck on a cycle, it keeps on flashing and won't start
try shutting off the power at the breaker panel and wait a minute sometimes rebooting will clear up a problem
Oct 27, 2014 | Bosch SHE6AP15UC Ascenta Evolution Series...
Where is the thermal fuse
Go to Utube and copy and paste this in : Bosch dishwasher thermal fuse replacement location . You will be able to fix it yourself with the videos .
Here is the link :
https://www.youtube.com/results?search_query=Bosch+dishwasher+thermal++fuse+replacement+location
Hope this helps , Grant
Aug 11, 2014 | Bosch SHE3AR75UC Ascenta Series 50 dBA 62...
What is error code E:25?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Error code details to many popular dishwashers are given.
May 07, 2014 | Bosch She3Ar75Uc Ascenta Series 24"...
Our Bosch Silence Plus 50 dBA shuts off and turns back on by itself.
You mean that you have to open it and slam it shut for it to finish?
Apr 25, 2013 | Bosch SHE3AR55UC Ascenta Series 50 dBA 42...
Bosch end cycle beeping
The Self-Help section in your manual states you can adjust the volume or deactivate the beeping signal. Instructions on how to do so are supposed to be in the "cycle completion signal" section of the manual which it appears the tech writers forgot to include in the published version of the manual. I have not worked with this particular model so your best option now is to call their customer service number and talk to someone that knows how to turn it off. FYI, their customer service phone number is 800-944-2904.
Sep 02, 2012 | Bosch SHE3ARL2UC 24" DLX Recessed Handle...
My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
Hello there,
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hope this helps.
Regards,
BElectric
Mar 16, 2011 | Bosch Dishwashers
Bosch SHX2AR55UC 24" Bar Handle Dishwasher - Stainless Steel Logo
148 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
