Question about Kenmore 63942 Dryer
Dryer won't starWt or turn over
When I hit the start button you will hear a sort of grinding noise. It wants to start then eventually the grinding noise goes away and nothing happens. For awhile if you would wait in between dryings you could get it to work but not always thru a whole drying cycle. It is as if it had to cool down. I think it has to be the motor.
  • 163 Answers
Hi!!! yes you have a motor problem.It could be very expensive to install a motor so shop around..Good luck.
Posted on Jan 21, 2009
Why do I hear grinding noises while driving?
Hit in the rear axle may have damaged bearings or brake parts. Jack up the side you hear noise from, put on stand, then have helper rotate wheel while you look underneath and listen to see where noise is coming from. Use length of old fuel or heater hose, one end in ear, to locate exactly where noise comes from.
May 27, 2015 | 1996 Jeep Cherokee Country
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My dryer seems to run rough. I changed the belt but won t turn with wet clothes. What could it be. Thx
I would say the dryer has a failed central ball bearing. You can say it by turning the drum manually, with the belt not installed and hearing for the tipical "grainy" sound of the rusted or stucked bearing.
Dec 23, 2010 | Frigidaire FER311FS Electric Dryer
With the power on, once I hit the "start" button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 07, 2010 | Kenmore 97566 Electric Dryer
We have a Maytag gas dryer that is probably 15 to 20 years old. It still works fine, but it makes a noise when it fist starts up. Sort of like a grinding sound .
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 27, 2010 | Maytag Dryers
Dryer is making a grinding noise when the drum turns
hi your belt is ready to give up take does it smell of burning if not it soon will take the name make and model to comet they will sort you another and they are very easy to replace you just open the back of your dryer make sure it is unpluged first take the old one off and just slide the new one straight on problem sorted
Apr 26, 2010 | Maytag SDG3606A Gas Dryer
I hit the start button on my maytag MDE9206AYW and it don't start
Sounds like the motor is going bad. If you keep going like that eventually you will hear a loud noise, and it won't even start.
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
When turning, loud grinding noise.
Can be a tensioner pulley with bad bearings or the rear drum bearing is shot. When the rear drum bearing goes bad, the drum drops slightly and starts rubbing and making all sorts of terrible noises. I would not run it like this as the pivot on the rear of the drum that rides in the bearing could be cutting into the support. Not a good thing.
Good Luck and hope this helps.
Mar 15, 2009 | Whirlpool LER4634J Electric Dryer
Dyer was grinding, then won't run
Sounds to me like you motor has froze up. Is there any smell coming from the dryer? The fuse would not cause this. A fuse would make the dryer do nothing when you hit the start button.
Nov 21, 2008 | Roper REX4634KQ Electric Dryer
1998 pontiac transport montana starting problems
It could be the starting motor is faulty or was not installed correctly, particularly if you are finding it turns over the engine slower than it should (dragging and dragging down the battery voltage). When starting the car, the teeth must mesh properly with the ring gear or all sorts of strange things will eventually happen. Alignment is controlled by shims on the mounting bolts and if they are the wrong ones or missing, also usually bad news.
Jun 25, 2017 | 1998 Pontiac Trans
Kenmore 63942 Dryer Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
