Question about Bosch 23 in. SHU3307UC Built-in Dishwasher
How do you reset the wash cycle on a Bosch dishwasher to the beginning?
The wash cycle was interrupted due to a plugged drain. It now needs to be reset to the beginning.
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
SOURCE: Our Bosch Dishwasher Not Draining After Normal Washing Cycle
make sure the filter is not blocked by anything like a straw or just junk
Posted on Apr 02, 2009
SOURCE: my bosch dishwasher whistles when on washing cycle
it is your wash pump
Posted on Apr 16, 2009
  • 98 Answers
SOURCE: Bosch SHX33A runs continuously. Never finishes cycle.
I have a guide here to walk you through the process of clearing the drain system. You most likely have a clog somewhere and the dishwasher can't proceed because it would cause it to flood.
Posted on Jul 27, 2009
Macmarkus
  • 2605 Answers
SOURCE: Dishwasher stuck on wash cycle
Based on your description I'd say the issue is with the control. Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described. Heck if you called me with this description I'd be happy to bring you a new control and have a first time complete. ( unless you requested a re-solder option...see below re: my opinion on this )
I digress,
As I've alluded to the issue is within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch servicer if that is an option for you and your budget however, If you cannot afford that option or feel capable of checking this on your own, there`s a way to visually inspect the control yourself. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes forever to finish and eventually display's the "1" error ( on models with a display ) because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
macmarkus :)
Posted on Apr 14, 2010
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
How can I interrupt my dishwasher cycle without causing it drain out all the water and then have to start from the beginning?
Hey friend, thank you for the post!
From my understanding you are trying to interrupt your dishwasher cycle without causing it to drain all the water out and then have to start it from the beginning. Once the door has been opened the wash cycle will stop and once it has been closed again your appliance would start up where the cycle left off. Hope this is helpful - Matt
Jul 20, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
SHE58C05UC/46 dishwasher won't complete cycle
sound like wash heater failure if it doesnt reach wash temp it will jump back to beginning of heat phase,thats why you get a lot of foam heat will suppress this as part of the wash action.
Jul 28, 2013 | Bosch Evolution 800 SHE58C05UC Stainless...
Error code 01 on bosch dishwasher. what does this mean?
error code 01 means interrupted heating phase or no heat on final rinse if machine is heating on beginning of wash this will be a blocked transfer hose or pressure chamber need to remove left hand side panel to access and base panel to access transfer hose it will be full of food deposits messing up water fill cycles these machines will only heat correctly when wash water is at correct level. the wash perfprmance will suffer till this is done.
May 27, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
I just replaced the drain pump in my bosch shu3307uc dishwasher.When I turned it on it filled with water and then I put it in the drain mode' It drained but it would not allow me to advance to start the...
You have to allow the drain cycle to finish completely, or find cancel drain dot points and press both at the same time, to reset program, open the door and close it to make sure the micro-switch activate properly
Jan 06, 2010 | Dishwashers
Reset model smu7052uc
there is none- if the program is mucked up-- pull the plug for 5 minutes
Jul 16, 2009 | Bosch 24 in. SMU70 Built-in Dishwasher
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch 23 in. SHU3307UC Built-in Dishwasher Logo
104 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
