Rinnai Glo Ray Heater REH-20FA Pilot will not stay lit
2 Suggested Answers
SOURCE: heater goes off with the
Probably the oxygen sensor faulty or lack of ventilation - this is a safety device to prevent carbon monoxide posioning - needs expert attention!
Posted on Jan 17, 2009
Pilot lite will not stay on when I release the igniter pressure knob REH-18-N wall heater!
IS there gas? YES ok. So if you can get the pilot lit, but when you let up on the button it goes out. Few things to check. On some heaters the manf. install a safety switch to drop the pilot out if its not venting or if its over heating.
Jan 01, 2017 | Heating & Cooling
The heater will shut down after about ten seconds.
Graham there are a couple of things that could be causing what you described.
The Oxygen Depletion Sensor (ODS) which is part of the pilot assembly could be clogged with dust, lint or pet hair. When this happens, the ODS reads the oxygen level as unsafe for operation. Using canned compressed air with a straw nozzle (like you clean your computer with) to blow out the ODS and the pilot tip should solve the problem.
Also, if the air louvers of the cabinet of the heater may also be clogged. Keeping them clean is important.
The Thermocouple, which keeps the pilot lit, may have failed. In which case it will need to replaced.
I hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 09, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
How do you light the rinnai glo-ray heater
Without pushing in the knob, turn knob to "IGN" position, THEN press and hold in knob while in that position, repeatedly press "Ignitor" button. (If it's the first time you've lit it, it may take up to 5 minutes of doing this to get the gas line supply full enough to light the pilot.) After the pilot is lit, continue to hold in "IGN" button for 10 seconds, then release, then you should be good to go.
Nov 22, 2010 | Rinnai Heating & Cooling
Pilot light on Dyna Glo gas heater won't stay lit
Cleaned pilot light area with an air compressor. Problem solved!
Mar 02, 2009 | Dyna Glo "" Natural Gas Heater Mn200tba
Heater goes off with the pilotlight had it for 3 years work great rinnai glo-ray reh-23dft-n
Jan 17, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Nov 22, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
770 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
