I can't get wireless internet on my wireless laptop
I can hook it to the router but when its unhooked it says no internet connection. i have an encore 802.11 router. model #enhwi-2an3.
  • 7,627 Answers
What is the laptop make, Model and the OS you are using? Is the wireless router Secured with a SSID and Security Key (password)? When you search for Available Wireless Networks, on the laptop, what is listed? Is the wireless adapter turned on?
Posted on Jan 09, 2013
  • 96 Answers
SOURCE: Problem with Encore 802.11n Wireless Router ENHWI-N2
Are you able to access internet when you are connected with a cable netween your laptop/desktop and router please check if yes then with the same connection go to http://192.168.1.1 default username admin and password "admin" and then check in the wireless tab is there any security on the wireless the same code needs to be entered on the laptop also in wirless network connections
Or the issue can be conenctivity between your service provider and router you may need to do some settings as per your service provider on the router for that again you need to open the 192.168.. page
let me know if this help, the below link will help you to check your connection once by one
Posted on Dec 01, 2009
  • 232 Answers
SOURCE: Encore Wireless Router Wireless connection problem
Do you have a key for the wireless? Double and triple check that your typing it correctly and that you have the correct authentication type eg - WEP, WPA, WPA2 etc.
Posted on Dec 15, 2009
Geekman
  • 32281 Answers
SOURCE: installing encore enhwi-g2 router wuithout cd rom
You can configure the wireless router from unauthorized access by connect a LAN cable from the computer to the router and open a browser and enter the router's configuration URL IP address.
To secure your wireless network from unauthorized access please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Mar 07, 2010
SOURCE: I need help to get my Encore ENHWI-G2 ROUTER
walang software ang cd ng enhwi-g2 encore. do it manually.
Posted on Mar 30, 2010
milan_cool
  • 65 Answers
SOURCE: i forgot the router 8
At the bottom of the router you can find the 8 digit pin code
Posted on Sep 27, 2010
Trying to run setup wizard on my WRT54G-TM,so i can block other people from borrowing my internet.I have one desk top hooked up and two laptops, works great ,but when i run the wizard disk it tells me...
To test your Internet connection, connect a LAN cable from your computer to the DSL or cable modem and if you can browser the Internet then your Internet connection is OK, then the problem is the LAN cnnection to the Linksys or the Linksys may not configured correctly.
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | Linksys WRT54G-TM Wireless Router
I dont know how to set up my routers
Put the setup disk in your computer and it will step you through the process.
Typically, you will have to hook your computer directly to an internet connection (with ethernet cable), then unhook it and connect the internet cable to the router (usually in port 1), then connect an ethernet cable from the router to your computer and plug in the router.
The disk should download the appropriate software and walk you through setting up a password and stuff.
After all that, you can unhook your computer and use it wirelessly.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
My router wont hook back to my laptop and i forgot the password
Go to your control panle then select network connections, if you see your wireless icon, right click it and try selecting repair first.
Also, if the wireless icon is in the lower right of the monitor, right click it and view wireless networks, look for you router, then select it. Then select connect.
Apr 22, 2009 | SMC Barricade Turbo Router
I moved my computer - unhooked the modem and wireless router and
Powerdown the PC, router, and modem then start the modem first then the router and finally power-on the computer... That should do it! Hope it helps!
-- Joshua79
Apr 04, 2009 | Belkin (F5D7230-4) Router (587009)
No internet signal from router in other ports
Hello, Under the wireless menu on router you must give a ssid name and enable and save to turn on wireless , hoe this helps?
Mar 21, 2009 | Linksys Wireless-G WRT54G Router
Link Sys wireless G router, connects with laptop, not desktop
first unhook router and hook up pc directly yo modem and type in 191.168.1.254 and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
THESE ARE DSL INSTRUCTIONS
Feb 16, 2009 | Linksys Wireless-G WRT54GS Router...
Problem connecting to internet from PC to laptop
mY lAB TOP WAS CONNECTED THROUGHdlINK WIRELESS ROUTER VIA bROAD BAND mtnl mODEM. iT WAS WORKING BUT nOW IT HAS STOPPED CONNECTION THROUGH YOUR dLINK wIRELESS.
pLEASE SUJJEST
Aug 10, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Hooking up to docking station
No, the laptop will have to have a wireless adaptor on it or in it to connect. The docking station is only good when the computer is hooked into it.
Jul 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
