Question about Lenovo Computers & Internet
Lenovo g580 the power lights are on but when i go to turn the on/off button the screen is blank but the power lights are on
I had this problem, I took it apart and cleaned my power button with alcohol. It had a sticky residue on it that was causing it to stay engaged sometimes, causing it to power on then off after 2 secs.
Posted on Nov 17, 2013
5 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Lenovo laptop G580 Power LED is not glowing
119 you must shure the adapter is o.k try to use in another computer or go to the repair shop for to tes.
2) use in the mode ONLY batte, and see if the power supply from the machine.
3) if the machine WILL get the LED ON, the power supply inside is faulty. Go to the repair shop COMPUTER for fix it.
or get the software from LENOVO, and download the software diagnostic .
God bless you
Posted on Sep 25, 2012
Pyrhyc
  • 2028 Answers
SOURCE: T30, replaced fan, no boot, no beeps
Did you replace the fan because of a no start problem, or something else?
Posted on Aug 30, 2008
freddygon66
  • 93 Answers
SOURCE: my lenovo n200 does on turn on it beeps and screen remains blank
Hi, you must remove both memories and return to wear them in the socket, it is for it that your equipment not power on correctly
Posted on Jan 20, 2009
SOURCE: Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Posted on Jun 24, 2010
Hi Friend My Laptop Lenovo G580,last week m y battery is not charge and Power light and Battery light frequently blinking.Can plz suggest.I am so Afraid about this issue.battery is still good
Price on battery $33-90. Will he laptop work OK RUNNING ON THE BATTERY ?? u can buy a new charger on E/BAY COST AU ,$18.05... Cheer's
Jun 28, 2016 | Lenovo G580 Laptop
How do i remove or reset the bios password on a Lenovo G580 laptop?
First of all, you need the present password. Then straight after turning the computer on you press F12 or insert multiple times after each other. That way you will stop the normal boot and enter the BIOS settings. There you most likely will be prompted for the password and then under security you can disable or change it.
Feb 21, 2015 | Lenovo IdeaPad Computers & Internet
My lenovo g580 wont boot unlesss i turnedon and turned on the power button
Check what it does when switched off. Does it actually shut down??
Jan 25, 2014 | Lenovo G580 Laptop
My lenovo g580 wont boot up unless i turn on and turn off the power button
That possibly is because it is in sleep mode and opening the lid will probably make it start up.
My lenovo laptop g580 wont boot even if camera and indicator lights are on
Sounds like a bad monitor or ram. Does the hard drive, fan etc make noise when first turning it on?
If there's noises indicating it's working, it's probably a hardware issue.
Jan 25, 2014 | Lenovo Computers & Internet
I have a Lenovo G580 and I'm having a problem with my screen, ones in a while my screen starts flickering, the screen turns off and on off and on, sometimes it just last a little while other times it...
I was having the same problem in lenovo s10 3s , but I took it to service station and found that the internal cable which connects the screen to base was loose. You too take it to service station because no power issues and os problem is to do with screen flikr.
Thank you.
Oct 02, 2013 | Lenovo G580 Laptop
Have inadvertently turned on narrator and screen is blank...can't turn narrator off, can't see pointer
I have the same issue....I reboot and get stuck. I also then hear an echo, but no keyboard button does anything. Help! I have Lenovo g700 and windows 8.1
Sep 01, 2013 | Lenovo G580 Laptop
Bios Flash
Are you sure you can't access your BIOS, or the OS selection screen?
In most PCs, the BIOS is accessible by DEL or F2, try to run those steps.
If the OS selection option is gone, you have to use another PC to Google the recovery process, and to execute it I am pretty sure you'll be needing your Opensus liveCD.
May 28, 2013 | Lenovo G580 Laptop
Factory reset lenovo g580
Step 1:
There are a variety of reasons you may need to reboot a Lenovo laptop. These can include the installation of a new program, the dreaded blue screen of death or to free up memory that has been hijacked by a program that is now closed. There are three ways to reboot and all are simple to accomplish.
Click on your start menu button on your screen. Click on "Shut Down" or "Turn Off Computer." Click on the drop down box if you are running a version of Windows before XP (such as 2000 or 98). Select the "Restart" option and then click "OK." On XP or later versions, click on "Restart." The laptop will then reboot. Press and hold down the "Alt," "Ctrl" and "Shift" keys simultaneously. This will bring up the Task Manager. Pressing and holding the same keys again will force the computer to shut down. Press the power button to reboot the computer. This feature should be used when the mouse has stopped working and you cannot access the start button. Hold the power button in the "Off" position for approximately 5 seconds. This will force the machine to shut down. Press or slide the button again to reboot the laptop. Use this process when you get the "blue screen of death" or the computer is not responding to either the mouse or the keyboard.
Feb 22, 2013 | Lenovo Computers & Internet
Computers & Internet Logo
1,436 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
