I have a ge dish washer model gsm1800jbb and the
I have a ge dish washer model gsm1800jbb and the handle latch (WD13X10030) had to be replaced...well it took a while to get it in and now we are not sure how to wire the wires. There are 2 white and 2 black and 6 different prongs so I am not sure which way to plug them in to make it work properly. It worked fine before it got stuck closed and wouldn't open, that's why we ordered the whole assembly. The way I have it wired it sounds like its working...water goes in and drains put but the arms on top and bottom aren't spinning and water is not coming out of them...it's just coming out of the side. WHEW!!! That's a lot of info...I hope it helps in solving the wiring issue!! If you have anymore questions please let me know!! Thanks for your help :-)
Buffalo12980
  • 625 Answers
SOURCE: used kenmore stackable washer and dryer P/N 145781-000A
was the machine working when you bought it? if there's 240 available, then a problem is in the machine NOT your wiring. both motors, the dryer and wash motor may be 240 volts OR 120 volts - a hot leg to ground. the feeder should be a four wire because the white is the neutral and the ground an equipment ground. at the panelbox both the equip gnd and white terminate at the neutral bus.
Posted on Sep 12, 2007
vest6
  • 196 Answers
SOURCE: installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Posted on Jan 13, 2008
  • 177 Answers
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
Posted on May 28, 2008
jsrock516
  • 5911 Answers
SOURCE: washer will fill agaitate but won't drain or spin
Have you checked the lid switch? A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know. NOTE: I don't know of any "safety switch" on the washer. You can, however, by-pass the lid switch to get it to work temporarily. It is by-passed by jumpering the plug in the console - not splicing any wires. I would not recommend by-passing any safety features, though. You may cause damage to the machine and/or anyone that attempts to use it.
Posted on May 14, 2009
john224
  • 1378 Answers
SOURCE: wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Posted on Jun 13, 2009
What is the part number to replace the door handle for wmd960g ultima
Hi Margaret
I'm having trouble finding the model or brand numberrs you've provided. If you look here
http://www.appliancepartspros.com/ge-washer-handle.html
you can see a selection of GE washer handles and their part numbers.It's selected for General Electric for vendor since GE manufactures
Hotpoint
Good Luck!
D
Nov 24, 2015 | Hotpoint Aquarius WMA42 Front Load Washer
When I hit the start button on my GE dishes washer the light in the front is blinking and it will not go on
This sometimes happens when there is a problem with the door latch system or switch. Your door may be closed but the control still thinks it is open. Check the door latch and switch alignment. GE had a problem with the doors dropping slightly about a year ago. the latch looks like a arrow head on top of the door center that pushes into the switch that is mounted on the dishwasher body. If the arrow head is slightly lower than the part on the body you will get the exact problem you are having. GE has hinge shims that they install to raise the door up slightly to fix the problem. Not sure your dishwasher is one of these without a model number.
Feb 28, 2015 | GE Dishwashers
Model w10311121b no power
Hi Scott. It appears you have the same dishwasher as mine bought in 2010- it worked sporadically for several years. I bought one year warranty ($289) in Feb2014 . Over 2 months, service technicians replaced 3 parts (user control board, motor control board and water sensor) hoping that each would fix it. They told me to run hot water before starting a wash cycle. Dish washing cycle failures were still sporadic and it finally lost all power in May2014. Service techs would not come out so I confirmed house power supply with a multimeter and then took the door apart to access the latch. I determined the latch kill circuit was not assembled properly and it had carbon buildup which I scraped off.
If your warranty has ended and you attempt this, do not use a power screw driver with these Torx screws as you can easily strip the threads or damage the plastic user control housing by screwing in too far on the top screws. (especially if you forget to reinstall the internal handle which acts as a spacer).
To disassemble: Remove the top 4 screws and top side screws, loosen the middle and lower side screws as needed. Separate the washer door face wide enough to remove the user control board, let it hang by the cord. The handle will be loose in the way, remove it. The latch has a white plastic kill circuit which is held to the latch with tabs. Unplug the circuit and carefully remove it. The circuit comprises 2 flat metal sheets that are pushed together by the latch lever when the door is shut. These plates separate when the door is open to kill washer power. The latch lever should be under both circuit plates with the shorter plate on the bottom. (long plate, short plate, lever, white housing). Reassemble, remember to include the handle My dishwasher operates properly now.
Apr 19, 2014 | KitchenAid Dishwashers
GE WSSH300G Front Load Washer drains, but won't spin. Repairman wanted $340 to replace a door latch. ???
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
May 25, 2011 | General Electric WSSH300G Front Load...
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
I have to replace the handle / latch assembly on a GE Monogram Dishwasher Model #ZBD6600G03SS. For the love of me I can't see how to do it. Do I have to get at it from inside, outside, both sides...
Hi
If the dishwasher door will not latch on your GE Monogram dishwasher and it is a new appliance, check that the door is not hitting screws or cabinets underneath the counter. For a new dishwasher, you might also need to push in the top of the control panel as you latch the door. The new gaskets might not have had time to seat properly. It may be necessary to run up to 10 dishwasher cycles for the heat from the washer to seat the gasket, which becomes more flexible after it is used a few times. For older Monogram dishwashers, check the loading rack to be sure no dishes are protruding beyond the back or front of the racks and that no dishes have fallen through to the lower rack. If dishes are dangling down into the lower rack, they could stop the lower rack from completely rolling into the dishwasher and could also stop the spray arm from rotating. Check that no silverware is obstructing the door.
http://www.acmehowto.com/howto/appliance/dishwasher/check/doorlatch.php
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Aug 03, 2010 | Dishwashers
I have a GE dishwasher model GSD1100G and the door will not latch now. Any ideas?
Yessir, I have a few.
1. Check the latch and strike. Usually, they're just loose.
2. Check the wiring to the switch. The lock and latch take a good bit of vibration being opened and closed.
3. Take a good look at the latch for physical damage. It happens. Your only recourse here is probably to replace the latch.
4. You didn't mention if the washer would run; the door latch is a permissive switch - if the washer will run, the switch is making contact, but the latch is defective. If it won't run, either the latch switch is bad, or the issue may be the control panel.
Best regards, --W/D--
Aug 12, 2009 | GE Dishwashers
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Handle broke off the dish washer
The latch and handle are an assm on this dishwasher part is going to run you about $45 -$50.
Mar 18, 2009 | Frigidaire 24 in. FDB750RCC Stainless...
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Nov 12, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
