Question about Canon MV850i Mini DV Digital Camcorder
Cannot insert a tape
I am unable to insert a tape into my camera. I have tried old and new, tried charging my battery, using a new battery, but to no avail. I am able to open and close the cassette door without a tape in it but as soon as i insert a cassette the machine will beep at me as it tries to close and then open out again. Please Help! I really want to use my video camera again! Hope someone out there has a solution , i will try everything! Thank you!!! :) amychloe02
This just happened to me today, apparently in my case it has something to do with condensation inside the camera, I don't know if this applies to you but at the moment I have the cassette slot open and in the sun, hopefully it will help, two hours apparently should do it. Give it a go, it can't hurt, I wouldn't put the actual cassette in direct sunlight though, so make sure you take that out. Hope this Helps
Posted on Jul 07, 2007
SOURCE:
How to fix a Canovision 8 VM-E1 camcorder?
replace the battery by the new one.
Mar 11, 2012 | Video Cameras
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
My focus lens is stuck in the open/out position. i cannot take photos, the screen says unable to focus. help!
It sounds as though the battery is low and the camera is faulting and has become "stuck" because of it.
I would suggest you try this first to see if it is.
Turn the camera off, take out the batteries and then re-insert with new ones or charge the old ones before you re-insert them. Make sure the batteries are fully charged.
This "should" jumpstart the camera back to the original configuration.
If this doesn't work please post back.
Hope that helps!
Nov 09, 2009 | Fuji FinePix S3100 Digital Camera
Code: 31:23....please reinsert tape. everytime i switch it on.
dear
u need to rate me for that ..ok dude....
actually this error is related to s reel i.e, the supply reel of the camcorder and some time when we insert a new tape in camcorder it start giving the error because the amount of tension is more in new tapes as compared to the old ones (used one) . . try to use the old tape u would nt have any problem .
but with new tape u will have these kinds of problem some times , to solve this problem for new tape u need to take the camcorder to near by service center of sony .nd they will align the tape path of your camcorder .
Jun 22, 2009 | Sony Handycam DCR-TRV265E Digital...
Tapes sounding funny
try using a smaller tapetime, the grinding noise your hearing is the gears of the tape take up within the casette not the camera, it seems the Sony tapes are 120mins long and the Sony tapes are heavier than TDK and your spool take up on the camera can't take it. the TDK tapes you were previously using may have been a shorter time than 120minute?...try any Hi 8 60min tapes instead. not the 120, they can be too heavy for the take up spool motor of the camera and all its doing is stretching and winding the cassette tape and unable to pull it with a 120 min cassette
Apr 24, 2017 | Sony Handycam® DCR-TRV250 Digital-8...
DCR-HC42 will not load Mini DV
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Nov 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Canon mv940 camrecorder won't power up even with charged battery
My friend went back to England and got it sorted there
Thanks
a
Sep 06, 2008 | Canon Video Cameras
Camcorder Battery won't charge
You know the watch battery that is often held under the screen? That battery is dead.
Apr 06, 2008 | Video Cameras
SONY DCR-HC39E
I had the same problem. I would suggest going to the service with it. The "head" needs changing.
Oct 13, 2007 | Sony DCR-HC39E Mini DV Digital Camcorder
Eo4 error code
HI SIR the fault is caused either by the take up or supply reel in the camera they are not rotating when the tape is inserted.maybe A defective tape or hung reel brake can cause this issue.or maybe a bad loosen guide of the tape path is lame , Try replacing the tape, if this does not resolve the problem you may need to seek professional service to have the reels checked. thanx and plz try to rate and remember i am here just to help u thx
May 08, 2007 | JVC GR-SXM920 Camcorder
Canon MV850i Mini DV Digital Camcorder Logo
189 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
