Won't go to menu even though I hold it in for 3 seconds
I am on record now but the problem is I can not get to the main menu
Well this is what you do when that happin. when it frize up like that trun it ff then trun it back on go to setting and change it around then go back to rec and when you stop it hit the return button and go back to the main menu. thats all to it hope i help you out later
Posted on Jan 21, 2009
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
How to unlock rp5020
Hi Louis
This is from page 5 of the manual:
Keys lock
This feature avoids accidental key activation during recording or
playback.
1. Press and hold MENU button for 3 seconds, LOCKED will be shown on display. (LOCK icon will lit) s
2. Press and hold MENU button for 3 seconds again to unlock keys.
You can a copy of the manual here: RCA RP5020 User Manual
Trust this helps
Alan
Jul 10, 2014 | RCA RP5020 Digital Voice Recorder
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
My recorder show HOLD how to clear hold
Hello
Reset the unit to its factory settings by the following methods.
Press and hold CH Up and CH Down button on the main unit for about 5 seconds.
(Current channel line-up and television program list are cleared.)
Select "Yes" in "Restore Default Settings" in the SETUP menu.
This returns all values in the SETUP menus, except for the clock, channel settings, ratings
level, and on-screen language, to the default settings.
While the disc tray is open, press [DVD] then press and hold REC button and Play/ [PLAY/* 1.3] BUTTON on the main unit at the same time for 5 or more seconds
Press and hold POWER button on the main unit for 10 seconds. (The settings remain.)
OK.
Mar 24, 2011 | Panasonic DMR-EH60 DVD Recorder/HDD...
I have a Thomson DTI6300-16 freeview box. I'm
This could solve problem
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Mar 05, 2009 | Arris DCT2608
SONY Cybershot 6.0 stuck on record
Initialize the Camera; select Initialize under Setup 2 Menu in the Main Menu. Reset the time and date. This should help
Aug 19, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Pace Sky plus box
You have 2 choices, software reset or hardware reset. It's up to you what you try, but please read the advice in full before starting - if you break your box, please don't blame me!
SOFTWARE RESET
The following is copied from http://www.ecademy.com/node.php?id=73309
This is useful if your disk usage percentage doesn't go down even after clearing programmesfilms off.
The following is offered on an ADVICE only basis, take care when making changes:
WARNING following this advice is totally at your discretion and anything which happens to your digibox as a result is your responsibility, not mine. You will lose all recorded programmes from your Sky+ Planner.
Sky tech support can talk you through performing a system restore over the phone. To do this yourself, press 'services' on your Sky plus remote, then select option 4. Next press 0, 1, select - you should now see the engineer's menu. Choose option 8, 'Full System Reset'. The box will now take a few minutes to reset itself
Try pausing or recording again, and if the problem persists disconnect the digibox from the mains power. Press and hold the 'left' and 'right' navigation buttons on the front of the digibox whilst you reconnect the mains power. Continue holding the buttons in for about 20 seconds, and when the ring of light on the front comes on, press the 'select' button on the front of the digibox (between the left and right buttons you were holding). The Sky+ recording logo lights will spin backwards and, according to the Sky engineer, this will "clear the hard drive".
Once this is done, disconnect the digibox from the mains power again and this time press and hold the 'back up' button whilst you reconnect the mains power. Continue holding it for about 15 seconds until 3 lights on the front of the box come on and you get a full-screen message saying "Updating system software. Do not disconnect mains supply or satellite dish."
Leave the digibox doing its thing for about 10 minutes and it should be fixed! Try pausing and recording things again... hopefully you've just saved yourself £65
If you've not been so lucky, you'll have to get Sky to fix it for you. Some people report that if you ask to cancel your subscription Sky sometimes offer a free callout to fix the problem - you're more valuable to them as a paying customer than the cost of an engineer callout
Sky customer service's (seemingly unpublished) freephone number. You need to dial 0800 731 6965, then option 2, option 4 March 9, Sky have closed this Freephone number
HARDWARE RESET
Copied from http://www.digitalspy.co.uk/forums/showthread.php?t=484098
Full System Reset via front panel:
  1. Remove power at mains.
  2. Hold LEFT+RIGHT.
  3. Apply power, wait for ring to light.
  4. Release LEFT+RIGHT, press SELECT.
  5. Ring cycles backwards while disk is quick formatted.
  6. If format sucessful PLAY lights up, if not RECORD lights up.
  7. Box goes into standby - wait 30 seconds are wake it up.
Warning: Full System Reset deletes all your recordings and planner entries.
Aug 07, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
AFTER 6 HRS RECORDING MESSAGE DISPLAYS NO MORE SPACE LEFT
It is true that the manual says it can record 100 or more hours...but that is at the lowest resolution. You can go to the menu screen and from there go to the recording properties and play around with different recording resolutions that best fit your recording needs. Also, the DVR uses a Hard Drive just as any computer does and within' time it becomes fragmented... that may cause it to record less hours even if you delete recordings. You can format the internal hard drive by going to the main menu screen and press and hold (for about 10 seconds) the OPEN and PLAY buttons on the unit (not the remote). At this time you should see the words FORMAT on the LCD screen and the unit will shut off. Keep in mind that formatting will erase everything on the hard drive so make sure you back up to DVD whatever you want to keep. Hope this helps.
Jun 23, 2008 | RCA DRC8030N
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
How do I Change from default language back to English?
To reset the settings back to English:
1. Set the DM-20 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-20 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-20 for at least 3 seconds. The menu list is displayed.
4. Click the REWIND button six times to highlight the Format menu item.
5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
6. Click the REWIND button once to highlight Start.
7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
8. Click the REWIND button once to highlight the Start menu item to continue with the format.
9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
Apr 07, 2007 | Olympus DM-20 Digital Voice Recorder
85 people viewed this question
 Grubhead
Grubhead
