What is the internal control fault on carrier gas furnacetont
  • 700 Answers
That would either be a flame rollout or a high temoerature switch going bad.
Posted on Jan 21, 2009
Just purchased an au ute on gas drives ok for about 20 or 30 kms then stalls in gear and backfires when you accelerate even slightly
take it into an auto gas installer/ fitter shop as there appears to be a problem in the gas converter
possible internal corrosion or diaphragm problems
have the fault codes read to check for coil pack problems or ignition control module or problem position sensors breaking down from internal heat ( indications of stalling and back firing)
Nov 06, 2016 | Cars & Trucks
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
What causes the nail gun not to fire
Your question isn't specific enough. Multiple things need to work together to fire a gas fired nail gun;
First the obvious user faults;
Low battery
Low gas
Nail guide jam
Not so obvious;
Broken/worn return springs (nail guide and firing bolt)
Faulty micro switches
Bent or impacted internal mechanism
Fan fault
Ignition or spark fault
Dirty or damaged ignition chamber (just like a car piston, cylinder and rings)
Faulty micro controller and ignition circuitry
Apr 19, 2015 | Tools & Hardware - Others
What could cause carrier fault code 42 besides bad inducer
Could be several causes.
1. Blockage on piping
2. Water in inducer housing slowing down inducer impeller
3. Condensate trap for furnace clogged up.
4. Inducer motor going bad.
5. Leak in vacuum hoses or not connected.
Welcome To the Best HVAC
Oct 09, 2014 | Carrier Comfort 13 Series 1.5 ton 14.5...
Carrier 2000ss will not turn on. Checked fuses and they are okay.
Inside the outside unit is a pcb with fault diagnosis lights on. It could be anything from a weak start capacitor to a compressor fault or even short of gas. See what lights are on and check the manual
Apr 21, 2012 | Carrier Heating & Cooling
While driving home in my 2004 Trailblazer it stopped driving while it was in Drive. I would press the gas and the engine would just revved.
MANY THINGS WILL CAUSE NO DRIVE PROBLEMS.IF TRANSMISSION FLUID LEVEL CORRECT LEVEL AND TRANSMISSION FILTER BEEN CHANGED.SINCE TRANSMISSION PCM CONTROLLED SCAN FOR FOR TRANSMISSION FLUID PRESSURE SWITCH CODE.OR TRANSMISSION PRESSURE CONTROL SOLENOID FAULT CODE.LOOK FOR SHIFT SOLENOIDS FAULT CODES.LOOK FOR TRANSMISSION CONTROL MODULE FAULT CODE AND TRANSMISSION RANGE SWITCH FAULT CODE.IF NO CODES COME UP.YOU HAVE TRANSMISSION INTERNAL MECHANICAL FAILURE LIKE FORWARD CLUTCH AND INPUT CLUTCH HAS WORN DRIVE PLATES AND LEAKING PISTON SEALS.FAULTY TRANSMISSION OIL PUMP.HAVE TRANSMISSION PRESSURE TESTED.
Dec 31, 2010 | 2004 Chevrolet TrailBlazer
We had a new Carrier Weathermaker Infinity Gas Furnace installed in our home on 9-21-99.The Carrier people said the furnace was in good condition this past October.But prior to that as of April 2010 the...
Your Carrier guys more than likely are Carrier dealers. I would get a second opinion. Most qualified HVAC techs can work on any and all brands. It doesn't need to be a Carrier dealer to work on a Carrier. AND, if they replaced the control board and didn't test the heat, that's a fault on their part. Anytime we change a board or even a thermostat, we check ALL modes and functions. SECOND OPINION!!!
Mar 10, 2017 | Heating & Cooling
Clicking noise at the gas valve/pilot light unit
It sounds like you might have a spark igniter on the unit that is being told to relight the burners. This is probably the tstat as this is the only control that "tells" the unit to come on. There isn't anything else internally that will cause this problem. Replace your tstat and I bet this solves your problem.
Apr 05, 2009 | Carrier 38BRC048 Air Conditioner
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
