Question about Datamax M-4208 Thermal Label Printer
Datamax I 4208 prints slow when set to landscape
I have a customer using a Datamax I 4208 printer, I support their ERP software and the software generates the print job for all barcode labels. In order for the labels to print correctly, the printer settings are set to landscape instead of portrait. This setting causes the printer to pause after each label is printed. The same print job sent to a laser printer set for landscape has no pause. We have increased the cache setting to try and improve the speed but this has not had an affect. I think the driver itself is the problem. Do you agree or do you have any other advice.
  • ctietschert Feb 25, 2009
    The driver in use is by Seagull Scientific. The program we are using is InfoMaker report writer by Sybase. The label format is using IDAutomation barcode fonts for both code 128 and code 39.
    I'll find out if it is serial or parallel. If it is serial, how do I speed up to the max?
  • 54 Answers
Try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Posted on Feb 25, 2009
  • Dave Busselle Feb 25, 2009
    If serial, you can go in to the setup on the printer and spin it up to 57,6k. If not not sure what to say.
    I am used to useing Bartender program, so not familiar with your SW.
    Also you can go into the advanced setting in the datamax and turn off pause after print.
HOW TO FIND THE ip ADDRESS ON A DATAMAX i-4208
To view or set the IP Address on a Datamax I-4208, use the Front Control Panel on the printer and follow these steps:
Press Menu, go to Communications, then NIC Adapter, then IP Address.
Jun 19, 2014 | Datamax I-4208 Thermal Label Printer
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
Zpl emulation with datamax i-4208
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Able Label Systems Thermal Printers
Feb 01, 2013 | Datamax I-4208 Thermal Label Printer
Datamax I-4208 has different position than i-4308 or prodigy max
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
Feb 17, 2012 | Datamax I-4208 Thermal Label Printer
Datamax I-Class I-4208 void
If the word "VOID" prints, turn the printer off, reboot your computer, turn the printer back on, and try printing again.
Oct 23, 2011 | Datamax I-4208 Thermal Label Printer
Can I print labels using DPL to a networked Datamax I-4208 using C#.NET?
greg babcok: You can do printing via tcp/ip packets or using Windows spooler. I have some example in vb.net
Roberto Martinez
padrino99@prodigy.net.mx
Apr 27, 2011 | Datamax I-4208 Thermal Label Printer
Datamax M-4208 label printer is not printing. It is showing paused status
probably a bad or very dirty sensor - use compressed air to blow out the sensors (look in the user manual to locate the sensors)
Dec 08, 2009 | Datamax M-4208 Thermal Label Printer
Datamax i - 4208
If you use ms-access you must have installed the windows driver, therefore you must enable the cutter in the printer properties. Position fault is that it does not detect the label, must be press the FEED key or to calibrate, press the FEED key for 5 seconds to calibrate the sensor label.
Sep 01, 2008 | Datamax M-4208 Thermal Label Printer
Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
Datamax M-4208 Thermal Label Printer Logo
751 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
