Question about ViewSonic VA2012WB Monitor
Monitor Warping the left and right sides
So I have a 20.1" widescreen monitor (from ViewSonic) and I connected it with my Xbox 360 to play videogames. But I've noticed that whenever something is near the edge of the screen (left or right) they get warped. Its as if everything in the very center of the screen is correct, but the farther you get from the middle. the more stretched things become. For example, a circle in the center of the screen will start stretching into an oval the farther from the center it travels. Is there any way to fix this problem?
BoiseLCD
  • 63 Answers
SOURCE: Viewsonic VX2235wm Horizontal Image Problem
Tricky one. Have you tried using different dispay resolutions from your Windows Display Control Panel?
ie 1200x1014, 1600x1400, etc.
When you say you used the manual adjust, do you mean the horizontal sync option?
Did you perform a Settings Recall?
And most monitors have a way of entering into an engineering "Factory Service Menu". Usually by depressing specific buttons while the monitor is OFF, and then pressing the power button while still holding the others. Then let all button go at once. From there, hit the normal button that you use for getting into the OSD. In the OSD, there's usually a new field with all kinds of cool new settings to play with. One of them being a soft reset. You'll have to search the net for how to enter into your Factory service menu.
Oh wait! I know!
If your picture has moved to the right, move yourself accordingly.
So that now you and your picture will be aligned properly.
He he he...
Kidding!
That one was from ViewSonic customer support.
Posted on Apr 03, 2009
  • 130 Answers
SOURCE: ViewSonic VA912b monitor fading out during boot
It is probably the power supply, or the inverters.
Similar problem with solution, though it requires you to know something about electronics.
http://www.badcaps.net/forum/showthread.php?t=6876&highlight=*va912*
Posted on Jun 12, 2009
Testimonial: "Problem Solved! Caps were spilling out all over the place. Sorry it took so long to reply >.<"
  • 691 Answers
SOURCE: The desktop and applications are stretched
right mouse click on the desktop and select properties. Then go to the settings tabe and change the resolution. A picture of the screen shape on that window should give you an indication of whether or not you have chosen a compatible resolution
Posted on Jan 06, 2010
budmrtn
  • 11361 Answers
SOURCE: How to change the picture format on my monitor?
You should set your PC to the monitor native resolution for this monitor: 1440 x 900 @60Hz.
Here is the spec for your monitor: http://www.dealtime.com/xPO-AOC-919Swa1-Black
Posted on Jan 27, 2010
Testimonial: "very quick and simple answer!"
mace1mace
  • 1138 Answers
SOURCE: Viewsonic VG2021m monitor no longer showing a picture
Hi!
there are possible reasons why your monitor shows nothing on your screen...
First, you need to check if the power cable of your monitor is well connected to a wall socket or AVR (and that you are sure there is supply output current on the AVR or in the wall outlet)
IF found that power cable is fix and secure... my suggestion is you bring the monitor to a credible technician...Because the possible reason why only black is seen on your screen, is because the backlight inverter could be busted already.. the backlight inverter which is located on the upper and lower back edge of the monitor is the light source responsible for giving image display of your lcd monitor.. Another reason could be is a deffective high voltage ballast transformer which is responsible for generating high votlage supply for the backlight....
It is too risky for you to do the repair by yourself without proper knowledge and right tools to do this.. So don't waste time consult a technician and or possible avail of the warranty if there is any...
Hope it is clear now to you..
Much appreciated if you rate this help.. thanks..
Posted on May 24, 2010
How get sound on viewsonic VA2446m?
Plug the audio cable from the PC to the audio input jack on the back of the unit. Then make sure audio volume is turned up on the PC side. The monitor also has a volume control setting. Make sure to have a value greater than 1 to hear anything.
May 15, 2014 | ViewSonic VA1912WB 19" WideScreen Monitor
Trying to hook up xbox 360 to computer monitor
Unless you monitor is HDMI capable I don't think it is possible without some sort of adapter.
http://godora.hubpages.com/hub/How-to-Connect-Your-XBox-to-your-PC-Monitor
Jan 19, 2014 | Acer P205H Widescreen LCD Monitor
My Acer S200hl monitor suddenly has horizontal white lines on the screen. It gradually fades from very severe lines on the right side to virtually unnoticalbe lines on the left. Any ideas?
It's dying. Pretty much simply that, something electrical or electronic (connections from panel to panel edge connectors, connection to circuit board, or internal to a panel matrix chip). Very likely unserviceable, if under warranty, take it back for service. Only other thing, check connector under back of monitor (if it has a connector at both ends). It's an Acer monitor, they aren't terribly durable, so if it's more than 2 or 3 years old, it's probably on it's way to deadville.
Dec 04, 2013 | Acer S200hl Abd 20" Class Widescreen Led...
What do i have to download to play xbox 360 games on the computer?
Sorry, but you cannot play Xbox 360 games on your computer. If you want to connect your 360 to a computer monitor, you can use HDMI if you monitor supports it or pick up a VGA adapter for the Xbox 360
Mar 06, 2011 | Microsoft Video Game Consoles & Games
Viewsonic VX2260wm has a shadow on the right side of the screen
install an AGP card in the AGP slot because internal display card of the motherboard does not support to high resolution because of insufficient memory . use 8X display card for the better result ..
Apr 18, 2010 | ViewSonic X Series VX2260wm 21.5"...
After waking from sleep mode, monitor resolution is a mess!
Try reinstalling the graphics drivers. and possibly a different graphics card.
Apr 14, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
How do we connect xbox consul to imac and play
There is no way to connect the original XBox console to an imac's monitor. There was never an hdmi or VGA connector that was worth buying made for the Original XBox.
The XBox 360 has a nice VGA adapter. But no the original XBox, sorry!
Apr 14, 2010 | Microsoft Xbox Console
Resolution
Your monitor is 4:3 and a maximum resolution of 1280 x 1024. Therefore you want to set your 360 resolution to 1280 x 1024 and you may want to change it to widescreen if desired. However, widescreen will cause you to lose some of your screen (i.e Letterbox). Try both standard and wide and see what looks better for you. If you are right up close to the monitor (about 12-18 inches away for instance), then widescreen would be ideal.
As for reference levels, it will depend on the contrast of your monitor. Try it on all three settings and see which one looks better for you. There is no wrong or right answer!
Jul 17, 2008 | Microsoft Xbox 360 Console
ViewSonic VA2012WB Monitor Logo
107 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
