Question about ASUS P5KPL-AM - Motherboard - micro ATX - iG31 - LGA775 Socket - UDMA133, Serial ATA-300 - Ethernet ... (P5QPL-AM)
My computer starts on first attempt only
My computer starts on first attempt and if i shut down it and try to start it again then nothing appears on screen. I m using window xp
  • sairaj Jan 15, 2013
    Hi i changes the ram with a new one but still same problem.
  • ASUS Master
  • 3,606 Answers
Hello the homepage is here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLAM/#download
Try to renew the graphic driver by:
Select windows xp.
Open the vga folder and click on global for download.
Unzip the file before you install.
Uninstall the old driver before you install the new.
The fault could also be the power supply, or a ram module failing.
I recommend at least 2 gb ram, for a smooth running system.
You can add a graphic card in the pci-e socket on the mainboard for better performance instead useing the onboard graphic.
Just make sure the windows system is driver supported.
Good luck
Posted on Jan 09, 2013
SOURCE: PROBLEM WITH ASUS P4VP-MX MOTHERBOARD
just replace your memory with a new one coz your memory is slightly defective. thanks. have good time
Posted on Nov 11, 2008
rickyostrom
  • 270 Answers
SOURCE: Windows XP not starting after power outage
You might check on the internet about making a boot USB Thumb Drive. This might be a work around a bad CD Drive.
Posted on Nov 19, 2008
ren3n
  • 8 Answers
SOURCE: ASUS m2n32 won't allow me to go into setup; shuts down...
Try to reset your BIOS by removing the button cell located at your motherboard and put it back. Check the SATA connector of your hard drive and make sure it fits right. Boot the machine and set-up to "boot from CR-ROM". And install new WINDOWS XP.
Posted on Jan 05, 2009
leecom72
  • 4806 Answers
SOURCE: mobo dies after 30 sec
Hi there.
Try and clear the CMOS, it will be a little plastic coloured jumper next to the motherboard battery like this >>>>>>>
If its there move it over for 30 seconds then put it back.
If its not there take the battery out for half an hour.
Please make sure you take the power cord from the back of the computer before taking the side panel off to get to the motherboard.
Post back if you need to and thanks for using FixYa!!
Posted on May 26, 2009
ansoopani
  • 93 Answers
SOURCE: breeds hill motherboard.upgraded ram to 1 gig.pc
may be u install wrong bios version
Posted on Mar 07, 2010
Pc won't start
Think your power supply died. Check that out first since they are relatively inexpensive. Or throw in a known working PS to see if that does the trick. Write back with results for further info.
Sep 17, 2017 | Packard Bell iMedia Computers & Internet
After charging battery, when I press start, it attempts to start and then immediately shuts down. After recharging the battery a while, and attempting restart, the same thing happens again.
Hi
Have you tried to use your computer when power charger is connected to power supply? Then try it to check if your computer does not shut down. If do not shut down it self. You had problem with the battery or with charger not compatible with the battery. Normal problem of shutting down computer is that your battery have no charge, your battery is not compatible with your laptop or ever defective. Tr
Jan 10, 2011 | Averatec 3200 Notebook
Looking for power up issue help please. Attempted to put comp. in to sleep mode by pressing keyboard button. Nothing happened. Went to windows xp start button and hit standby, nothing happened. Did this...
few things to try you can disconect the hdd the dvd rw drive and anything elce conected to it appart from the motherboard and moniter then try again (just becouse you tryed to check the psu it my well still be completly broken ) i would probly suspect the motherboard in this case thought i would try a new psu first as this cost less (10 pounds from ebay) hope this helps ps reset the bios and cmos too
Jul 10, 2010 | HP Pavilion a1250n (EG194AA) PC Desktop
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Computer will not re-boot
your hard drive has been corrupted due to improper shutdown
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Computer hangs up on shutting down screen
Ok.....
1. Make sure ALL user accounts are logged off!!!
2. UPDATE ALL DRIVERS
3. Check to see how many Programs are running while attempting to Shutdown the PC..(the more programs it tries to close, the longer it can take...(ESPECIALLY WITH LOW AMOUNT OF RAM/SLOWER RAM)
Mar 22, 2009 | Toshiba Satellite Laptop with AMD Athlon...
My Presario SR1750NX won't boot up
hold the power button for 10 seconds it turn off ur cpu and then start the cpu and hold F5 key u get windows boot menu select safemode try to login after login check in the controlpannel poweroptions chek in advance option see the menu down wheather it is in standby then change it to shutdown and apply the setting. and check it out it may work r else please try to repair the os.
Feb 10, 2008 | HP Compaq Presario Media Center SR1750NX...
ASUS P5KPL-AM - Motherboard - micro ATX - iG31 - LGA775 Socket - UDMA133, Serial ATA-300 - Ethernet ... (P5QPL-AM) Logo
47 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
