Question about HP Vs17 17" LCD Flat Panel Monitor
How do Iopen the case of an HPvs17x monitor?
When power is applied the power switch blinks and the screen dosent light up.
  • 1 more comment
  • lawindell Feb 19, 2009
    when i turn my computer on and then my hp vs17 monitor the led power button keeps blinkng blue and it never turns to amber or stay on blue with a monitor display. is it new monitor time?
  • John Bruggeman
    John Bruggeman Mar 16, 2009
    The power switch light blinks and the monitor never comes on.
    What is the problem and is it repairable?
  • ratpack_6th Apr 09, 2009
    When I turn on the monitor, the power button blinks off and on blue, but there is no display on the monitor.
  • 33 Answers
The Capacitors on the power board are usually the reason for failure of an LCD. If you open the HP VS17 ( I can provide an exhaustive step by step If I have to) remove the five screws for the power board ( larger of the two boards) and look for an area where there are 4 caps (see pic). Look for exploded, popped up, bulging, or leaking caps and replace with the same or slightly higher tolerances. The one I replaced last night were (2x )1000uf25-50volt and (2x) 470uf25-50volt. Check the rest of the board for similar issues and replace as needed.
Posted on Sep 15, 2009
To remove the case of a VS17e you must first remove the base/stand. There are 3 screws to remove, in back of the LCD holding the base/stand. Two are visible and one is,only, available once you remove the top silver plastic cover on the stand.
Then you can pry apart the front silver plastic bezel. Another tip is to remove an aluminum cover on the top side of the metal LCD case to disconnect the data cable to the LCD screen.
Careful with the speaker wires once you decide to assemble back together.
Posted on Feb 16, 2009
  • 105 Answers
The front and back covers snap together. remove the base and any other screws visible from the back, then pry the front and back apart with a flat blade screwdriver.
Mike
Posted on Jan 21, 2009
With regards to solution #2. I have removed the round metal baseplate and the top plastic cover on the stand. The front of the display was pried open. It was clear that the tilting mechanism was held to the metal frame which houses the electronics. So, back to the upright which comprises 2 of the 4 discrete sections making up the stand. The 7 cm long section of the roughly rectangular-in-cross-section, silver plastic between the 2 cm long rounded piece actually housing the tilting mech. and the formerly attached circular base must be removed next. It is held by 5 plastic tabs as I see it. Did you mean that these must be pried apart? I don't see any other way
Posted on Jun 20, 2009
  • wildlife365 Jun 20, 2009
    Answered my own question. In detail, here is the procedure:
    1) Remove metal bottom from base - 8 screws, a few under the rubber.
    2) Squeeze the now visible plastic tabs together to remove the round plastic from the upright.
    3) Inside the upright, at the end nearest the titl mech. you will see 5 plastic tabs. These do not allow the upright to be removed, however. Their purpose is to hold the rounded plastic cover located between the upright and the panel to be removed. start on 1 long side, apply a steady gentle pull on the rounded piece and pry the two tabs along that side. As you free up a couple tabs, the others become easier to separate.
    4) Once the small plactic cover is removed, you can access the 3rd screw holding the base to the panel.
    Habit-Forming:
  • 12 Answers
I also have an HP VS17e with a blinking power indicator, won't power up. I managed to remove the exterior plastic housing and the small aluminum cover to get access to the ribbon cable, but I'm baffled by the connector. I have experience with several types of miniature ribbon cables, but this particular one has me stumped. How do I disengage it without damage?
Posted on Oct 11, 2009
We managed to remove the base and screws.
How do you open the case without damaging it?
We think there is more dust in the monitor, after using the vacuumcleaner and hitting on it the monitor it works again, even the blue powerlight came back on.
Thank You
Greetings.
Posted on Sep 05, 2009
My nokia 3110c got switched off. then when i
Nokia 3110c while charging the battery& while taking its got switched off.
Jul 26, 2010 | Nokia 3110 Cellular Phone
HPvs17x power flicker on/off no image, 3-10min after image ok!
More likely to have failing power supply problem due to bad caps, look for caps with bulging top first and post back what you see inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 02, 2010 | Computers & Internet
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
Blue light flickers, but no picture
I have a gatway fpd2185w the blue light blinks and then dims and the power button dosent work.
Jun 28, 2009 | Gateway FPD2185W 21 in. LCD Television
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Computer dosent turn on..screen is blank with blinking LED
have u tryed
unplug all of your plugs at the back like blow on them like i do to get lil partcals of dust out then plug all back in and mite work or maybee ur power cord is screwed a bit and u mite have to get a new one whats happednd to ur comp happend exactly the same with mine and i screwed with myn for ages and it finaly worked so maybee just try all that n then if that dosent work as drliativ hes a good guy and will help
hes helped me out a few times hes a great guy
Dec 02, 2008 | Smart Modular SV3170A
Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Flickering switch light, blank screen
Hi, First of all it is not advisable to open up monitors without proper tools as they contain hazardous elements. Dell monitors however do have a 3 year SEPARATE warranty. Check on the back of the monitor and look for the monitor serial number. is should start with CN-xxxxx-,, or JP-XXXXX-. give that to a dell tech and they should be able to replace that.
Oct 01, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
1,511 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
