Question about Sony PlayStation Portable (PSP) Console
We have a psp that wont turn on.
The psp does nothing when trying to turn the power on. We can't fnd the power cord so we are trying to charge it the way it says in the manual , by ising the usb port. Help!!! What do I do?
  • Anonymous Jan 21, 2009
    my PSP will not turn on or charge whether or not it is plugged in via an AC adapter or USB port. No lights come on at all, either.
    Can the battery be blown?
  • chicksrule10 Jan 21, 2009
    it just wont go in i tried EVERYTHING
    Scholar:
  • 72 Answers
You probably blew a fuse undo 4 black screws (2 underneath the warrantee sticker under the battery) and the chrome screw bottom side of case take of the face lay down flat and up the top to the left you will see f60012.5get a lend of a multimeter and check for continuity they are a 2.5 amp fuse very small if you have a aftermarket power supply that probably blew it dont use again if you have good luck
Posted on May 21, 2009
    Problem Solver:
  • 11 Answers
You may have bricked your psp if you updated it and while it was updateing you turned it off if you did this then the only way to fix it is if you used a pandora battery or take it to sony to get it fixed (not cheap)
Posted on May 16, 2009
  • 132 Answers
You can only charge a slim psp via the usb cable and if no led comes on, take out the battery and try turning the psp on with it plugged into the wall outlet.
Posted on Jan 21, 2009
I pluged my psp into my Computer and it just wont charge, it wont turn on wither
Either the battery is shot and will no longer charge ( you would need to replace the battery) or the cord you are using is bad. (try a new cord to hook it up with)
Mar 21, 2011 | Sony PlayStation Portable (PSP) Console
I have my psp plugged in to the power cord for over a day, still not charged and it wont turn on at all. why ?? please help!!!
Probably, either the battery or the charger is busted. Try borrowing a friend's PSP charger and plug it in. The power led of the PSP should turn orange when charging. If it still does not charge, you might need to replace the battery.
Jul 13, 2010 | Sony PlayStation Portable (PSP) Console
My sony psp go wont charge...
Try a different outlet in the wall, it might be the outlet. If it isn't the outlet, maybe it's the power cord. Try to use someone else's PSP charger and see if it works. If it If it's not that, then it's your PSP. If you had it since launch then it will cost $90 to get fixed.
Jan 10, 2010 | Sony PSP (Piano Black)
Psp carge light wont come on and psp wont turn on
You either have a bad battery, or a bad power supply that charges the unit (power cord). If you have a friend that also has a PSP, try swapping out the battery to see if that works, and or try another power cord to see if the charging indicator light comes on. I think that possibly your battery is dead and the power cord might be bad. You can find good deals for both the battery and cord on ebay. Good luck!
Nov 07, 2009 | Sony PlayStation Portable (PSP) Console
Psp won't charge when plugged into computer
u cant charge on a computer unless you have a charger that hooks up to it...are you sure your using a charger or are you using the cord that transfers data to ur psp! the data cord will not charge ur psp its not a charger all it does is transfer data sorry you need a charger for the psp not a data cable
Jun 18, 2009 | Sony PlayStation Portable (PSP) Console
Ipaq h1945 wont charge
The power cord was tampered with by my siblings, I'm currnetly using my psp cord.
Nov 16, 2008 | Computers & Internet
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    MY PSP WONT TURN ON
    maybe you need to get an new screen inside or charge it
    Jul 06, 2008 | Sony PlayStation Portable (PSP) Console
    My psp wont charg
    If it won't charge and wont power up then same thing happened to me. If you are willing to open up your psp there is a video on youtube that can show you whats wrong. The cable that connects the buttons on the right side most likely disconnected from the main board and the right side of the psp including the buttons, the power switch and the top right trigger won't respond. When you try to turn on the psp and when its charging if the light won't come on then you might have this problem.
    May 10, 2008 | Sony PlayStation Portable (PSP) Console
    My psp wont power up
    psp IS bricked you can repare it yourself with a pandora battery go here for more info: www.consol-crazy.com
    Aug 17, 2007 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    164 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
