Question about Toshiba Satellite P205-S6287 Notebook PC
Problem turning on - Frozen startup screen
Ok, my computer wouldnt shut down, it asked me if i wanted to shutdown even though other users might be using the computer or whatever as per usual, and then wouldnt shutdown, so i held in the power button :(, as it was the simplest way.
then when i turned it on again it goes to the boot page or whatever you call it, with "toshiba leading innovation >>>" and it freezes and wont even let me get into boot from cd or setup.
please help, ty
  • mentally_ill Jan 21, 2009
    by the way my comp is an satellite X205-S9800 if that matters, and its when i press the power button it gets to the [F2] and [F12] option stuff but its frozen
    its when i press the power button and its just turning on it freezes and i cant press [F2] or [F12}
    Genius:
  • Toshiba Master
  • 1,102 Answers
I want you to restart and then pressing F8 while in restart try to get into LAST KNOWN GOOD
if it won't boot that when then restart again pressing F8 then start in SAFEMODE
While in safemode open control panel and then users
click on your user name and make sure your settings are still there
close off user and open display click screensaver then power and make sure your settings there are correct change stanby to never and then go to hibernate remove check then click apply close it off.then see if you can restart
PLEASE LET ME KNOW IF THIS HELPED
IF NOT I CAN FURTHER ASSIST YOU
Posted on Jan 21, 2009
Acer aspire doesnt boot
You are missing the Windows Boot. No Operating system!
Dec 05, 2013 | Acer aspire 5733z4851 intel pentium...
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
How do I shut off my computer? L670 series
Normal shutdown: Click on Start button (lower left corner on most PC screens), and then select shutdown.
Abnormal shutdown: If computer is "frozen" and you can't click on Start button, press and hold the power on/off button until the computer shuts down.
Jan 24, 2011 | Toshiba Computers & Internet
I attempted to shut the computer down via the startup menu but closed the laptop prior to it shutting down. When I reopened and turned on it asked for password to log into windows but the hour glass...
Try pressing and holding the power button until the computer shuts down.
Also note that when removing the battery, you also need to unplug the power cord in order to shut down the computer in that manner.
Dec 29, 2010 | Computers & Internet
Windows will not turn computer off. I have unpluged every thing and all fans but the hard drive. I get 0.01 dcv when the computer is running and the same when I try to have windows turn the computer off....
This usually happens if Windows is having trouble closing a program. The easiest way to avoid the problem is to close all programs before you close Windows.
If that does not help, you need to track down which program is causing the problem.
If you are running Windows 95, remove all shortcuts from your StartUp folder.
If you are working with 98/ME/XP, uncheck all the programs listed in StartUp in the System Configuration Utility (you get to the utility by opening Start/Run and typing "msconfig" without the quotes in the Run box and then clicking on OK).
Shut down the PC. Reboot. Shut down again.
Then add one program back, shut down, reboot and shut down again.
If Windows shuts down as it should, add a program back to StartUp and repeat the shutdown, reboot, shutdown routine. Do that until you have pinpointed the errant program and reinstall it. If you are running a screen saver, consider it also to be a prime suspect.
Your Advanced Power Management, or APM, utility has decided to take leave of its senses.
Disable it, both in your BIOS file and in Windows.
That little sound riff that accompanies the shutdown is hitting a sour note.
Go to Control Panel and click on the Sounds icon to open the Property dialog box.
Scroll down in the Events box until you see Exit Windows. Change the sound settings to None.
Your TEMP folders are bulging at the seams.
If the C:\Windows\TEMP folder gets overloaded, all sorts of bizarre events can ensue. Clean it out. While you are at it, clean out your Temporary Internet Files folder as well.
Updating XP with the latest Service Pack may also cure the shutdown failure.
However, it is also possible that Advanced Power Management, or APM, is getting in the way of the shutdown routine.
APM may not be enabled in your XP configurations, but it may be turned on in your BIOS, a memory-resident program that controls how your PC sets itself up.
Microsoft recommends that you go to the Control Panel, click on “Performance and Maintenance,” and choose Power Options.
Click on the APM tab and click on Enable Advanced Power Management Support.
Personally, I don’t like automatic power management on desktops because it can cause all sorts of bizarre behavior. I would leave Advanced Power Management disabled in Windows and turn it off in the BIOS.
Consult your PCs manual to determine how to enter BIOS’ Setup file. Sometimes, as the PC boots, you can see a message on the screen that tells you which key to press to enter Setup. Press it before the screen welcoming you to Windows appears.
Once in Setup, look through the various sections until you find the option for controlling power management. Choose to turn it off.
For guidance on other XP shutdown problems, consult article 308029 in the Microsoft Knowledge Base. Use the article number as a search term at the support site below. Good information is also available at the aumha.org site.
Regards.
Aug 27, 2009 | Computers & Internet
Windows xp startup and shutdown has changed!
To configure Windows XP to use the default logon and shutdown screens for every logon session, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click User Accounts.
  3. Click Change the way users log on or off.
  4. check the Use the Welcome screen check box.
Thanks
proton
Apr 04, 2009 | Microsoft Windows XP Home Edition
Computer won't restart or shut off
I had the same problem & I'm running the same OS. It happened after an update too. This is what I did. I made a new shortcut on my desktop for shutoff & restart, I just use this shortcut now & it works OK. If you want to try it this is how I did it...
XP Users:
1. Right click the Desktop and select New /Shortcut.
2. A screen will appear asking you for a Command Line. Here's what you put in that box: ( it's best if you copy & paste this into the box)
For Shutdown:
Shutdown -s -t 0
For Restart:
Shutdown -r -t 0
Feb 28, 2009 | Microsoft Windows XP Media Center Edition...
Startup/shutdown
Sounds like a failing hard drive.
Have you got an XP or Vista cd around?
Feb 25, 2009 | HP Pavilion TX2510US Notebook
Toshiba satellite x205-s9800 - Frozen boot screen
hi,
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
Jan 21, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Automatically retarting when I shut down computer
2000 Is Windows 2000. Why did you put that disk in? Did you start loading Windows 2000 or XP Pro, XP-Home?
It sounds like your switch is wired to the reset jumper on the motherboard or you are hitting reset.
Tell me what the computer screen has on it before it shuts down please.
I will wait on you answer. Do not rate until we are done.
Jun 10, 2008 | Computers & Internet
Toshiba Satellite P205-S6287 Notebook PC Logo
186 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
