Question about General Electric GE CR127B5 Bellows Actuated Pressure Switch
Location of GE hot water heater pressure switch (sp20313) location/replacement
  • 659 Answers
SOURCE: elec water heater no hot water
Check the breaker to see if the unit is getting power. You will need a voltage meter to check out the thermostat on the unit and also you will need to use it to check if the elements aren't blown. Sounds like the unit isn't getting power but could be the thermostat located under one of the panels on the side of the unit.
Posted on Mar 20, 2009
jj505
  • 195 Answers
SOURCE: GE Hot Water heater about 2 months old - today no hot water -
Turn dial from vacation to higher setting liker warmer if not hotter if not already there. If this does not work let me know. Please rate. jj505
Posted on Mar 29, 2009
  • 297 Answers
SOURCE: My GE smartwater hot water heater has no pressure.
try to open and close the valve at the unit,this shut off valve may have gone bad,replace it this may help.
Posted on Jul 29, 2009
SOURCE: I own a house with
GE is made by Rheem, but the market is always changing. Rheem-based serial number shows tank was made in 1990.
Tank will last as long as anode rod(s) protects steel tank from rusting.
If your tank has two anode rods, then tanks lasts longer.
That's how companies determine if water heater is '6-year' or '12-year.'
I don't have manual for your product to say if you have 12 year tank. Side of tank might have information blurb besides mandatory label that shows serial number.
You can update your water heater by replacing anode rod(s) assuming they can be loosened and removed after this number of years, which is a big IF with old heaters. Your plumber might have impact wrench he uses to see if anode can come out.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Leaking-water-heater.html
If the water heater is making gurgling rumbling and/or crackling sounds then tank has sediment build-up.
You can also get a baseline of rust by flushing tank and watching if water is very rusty.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Water-heater-will-not-drain.html
If you flush tank regularly, and inspect anode every 1-3 years, a tank will last many years longer than manufacturer's label.
http://waterheatertimer.org/Water-heater-manufacturers.html
Posted on Apr 21, 2011
ultrat
  • 500 Answers
SOURCE: I replaced the heating element
Does it have a reset on control ..check breaker .. use a volt meter on high setting check power at element work your way back find where power stoppes..
Ge gxrm10gbl02
Copy following link:for water heater and to locate source of clog
http://waterheatertimer.org/Low-hot-water-pressure.html
Call plumber
Call GE
Gene
h
Oct 01, 2013 | Water Heaters
GE hot water heater pilot will not lught
Bad gas control valve.
Low gas pressure.
Bad themocouple
FV lockout caused by overheated combustion chamber due to flammable vapor, poor venting, or clogged air intake
Clean air intake located on bottom of heater.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
Copy following link for troubleshoot by type of gas control
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/How-to-replace-thermocouple.html
Add a comment with results.
Oct 13, 2012 | Water Heaters
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
My GE smartwater hot water heater has no pressure. what are some troubleshooting thing i can try?
Jul 29, 2009 | General Electric GE SmartWater Household...
Hot water heater doesn't work 2 years old
First I would check to be sure your propane tank(s) are not empty and valve is not turned off and that the required gas pressure is being delivered to the unit i.e. pressure line tubing is not kinked or leaking - pressure regulator is operating properly.
Another culprit could be the thermocouple is malfunctioning or is not positioned properly, hence not allowing it to sense the flame.
Feb 21, 2009 | Water Heaters
General Electric GE CR127B5 Bellows Actuated Pressure Switch Logo
Top General Electric Water Heaters Experts
paulcarew
Donni Steen
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
