Question about Electrical Supplies
Generator Wiring I need to locate a wiring diagram for a 3500W 6.5Hp Honda Clone generator. I inherited this like new, less than an hour of running time, dated generator. Most of the wiring is still intact as far as the power supply side which I can figure out but the key ignition switch, solenoid, starter, low oil sensor breaker wiring side has been compromised. It's a WENLING JENNFENG family 5WJFS.1961GA. I believe similar to a Home Depot product. For the likes of me cant locate a schematic that I can trace of off. Can anyone help?
3 Suggested Answers
  • 1723 Answers
SOURCE: I have a Honda generator model EM3500X with auto
The control board that senses load (current) is not working.It should drop to low with no output current. (nothing running)
Posted on Jul 07, 2009
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
I need the wiring diagram on a Honda generator model eu2000i for the front cover on the inside any the wire diagram
Type maker, model, user manual in computer search engine. It will bring up sites to get user manual. In the manual, there is a wiring diagram
Dec 13, 2015 | Honda Electrical Supplies
I need a parts book for a wenling jennfeng 3800 generator
I have a cheap wenling Jennfeng 3800 generator someone ...
Sep 26, 2015 - I have a cheap wenling Jennfeng 3800 generator someone removed wiring from bridge rectifier i ... If you are replacing parts on the board please send photo. ... Snap-On book says the part number is BC4200-2000R but it.
wenling jennfeng industry 79 5cc generator parts Questions ... > Forum > Tags
Find solutions to your wenling jennfeng industry 79 5cc generator parts ... My 6.5 Hp Honda Clone 3800W Wenling Jengfeng 5WJFS.1961GA runs fine off ... Bank Swift Codes I need the swift code for Bank of China Wenling Sub Branch Hi there, don't know if you speak Chinese, but here is a list of swift codes for branches of ...
jennfeng generator parts Unsolved Problems - Fixya
Dec 08, 2015 | Electrical Supplies
the generator is not big enough to run what you want
it needs to be 3500w minimum or 4.5w to be safe
although it is stated at 2500 watts , in fact that is the peak load on electric motor start up and its continuous rating will be around 1.8 watts
all of this is clearly stated on the specs plate on the generator
Dec 06, 2015 | Honda Generator E2500 Vintage Great...
Generator wiring for a single wire generator
You can't have a single wire generator. It needs an earth and a positive for a generator to work.If it only has one wire it is a dynamo. and you don't need a wiring diagram for one wire.
Jun 21, 2013 | Harley Davidson Motorcycles
When you put a load on generator it powers up and down and tries to cut off.
sounds like you are trying to put too much of a load on your generator. I have a 3500w generator and when I hooked it up to my 120v (not sure how many HP) well pump when the pump would try to cut on the generator would bog down and even die. took off the load and started right up. will run other things just not heavy loads. maybe you need a bigger generator for what you are trying to power.
Oct 28, 2010 | Honda Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
Aug 11, 2009 | Electrical Supplies
I have a 3500w coleman generator I use to run my 5th wheel. It works fine until I turn on the air conditioner, then it sounds like it is bogging down and will not power the A/C.
Hello, I will make the assumption that your A/C runs fine when you are tethered to shore power. You will need to calculate your load. Add up the amps of everything in use, including the A/C. 3500W is the peak momentary output; look at your data sheet or tag to determine your continuous output, which will be less. It's possible that you're either pulling too many amps for your genset or there may be an issue with your A/C. Turn everything else off, and start the A/C. If the generator bogs down, you may not have enough generator. If it doesn't bog down, turn on your other items, one at a time. Ideally, your generator should have enough output to power everything in your 5th wheel, plus ehough extra for initial starting surge, like for your A/C, fridge, etc.. It sounds like your amps are close, but not quite there.
Regards, --W/D-- Please feel free to rate my solution! Thanx!
Jul 29, 2009 | Coleman Powermate Premium Plus 6250W...
I have a onan genset generator model #3.0AJ 1R/16017S serial # L830689411. It is wired wrond to my motor home it runs good but no electricity coming from generator to motor home, which is a 1982 coachmen....
The wiring diagram for the generator is pretty simple. You have three wires coming out, White/Green/Black. The black is the Hot, White is neutral, and green is ground. If the generator is running and you do not have power at the black wire, the problem is in the generator. Check the circuit breaker on the generator for OK. Make sure that power is passing through it.
Jun 16, 2009 | 1983 Chevrolet Chevy
Electrical Supplies Logo
60 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
