Question about Epson TM-L90
Printer problems... Hi, I purchased a 2nd hand Epson TM-L90 printer and I'm having some problems with it, I've also just purchased the correct serial and power lead and was supplied drivers for the printer. After installing the Epson Advanced Printer Driver and printer doesn't printer on command, infact it only prints loads and loads of pages of ???????????? this only happens when I restart my PC, very weird. The printer is connected to my PC from serial to serial ports (25 pin) I have also tried to change the setting from different ports but still without any luck. Tried to testout the 'Print Test Page' in CP under printers but yet again nothing happens, not even ???? Does anyone know anything I maybe doing wrong? Any help or helpful advice would be most appreiated. Pete
  • Peter Brewer Jul 01, 2007
    Thanks for the response.
    I have a new problem now, everytime I turn on the printer it prints out continuious pages of ?????????? and it doesn't stop.
    I have tried turning the power supply off and taking out the serial port to the PC, and even uninstalling all the drivers/software.
    Is there another way of reseting this printer?
    Thanks,
    Pete
  • 944 Answers
It sounds as if the port is trying to operate a mouse - giving the ???????. If you have windows XP then go to control panel, printers and faxes, then click "add a printer". The add printer wizard starts up, click next. select the "local printer" option and make sure the "automatically detect and install....etc" option is turned off. Click next and you should be able to select printer port. If you are using the serial port COM 1 (usually the only one externally on the pc), then select it from the list and follow the wizard through to the end. Restart the PC and you should hopefully find that the port has become dedicated to the printer alone. if still problems, go to device manager, right click on the COM 1 port and select properties, it should allow you to start the troubleshooter for the port. This should help. Other operating systems will have a similar procedure. Also worth trying is to uninstall the epson drivers, restart, plug the printer in and turn it on, and see if windows will automatically install the printer without the epson drivers. If it will, then let it do it's stuff and hopefully it will work. Hope this helps :)
Posted on Jul 01, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Jul 01, 2007
    Have been looking through the manual (sorry no link to it - you have to register with epson as a service contractor to get it). There is no reset as such, but there is a list of DIP switch positions;
    switch 1-1
    Power switch function
    on=Disabled
    off=Enabled
    1-2
    Interface condition selection
    on=by DIP switch
    off=by memory switch
    1-3
    Handshaking
    on=XON/XOFF
    off=DTR/DSR
    1-4
    Data word length
    on=7 bits
    off=8 bits
    1-5
    Parity check
    on=Enabled
    off=Disabled
    1-6
    Parity selection
    on=Even
    off=Odd
    1-7 and
    1-8 (in order)
    Transmission speed
    on/on=2400bits per second
    off/on=4800bps
    on/off=9600bps
    off/off=19200bps
    switch 2-1
    Reserved
    Fixed to Off.
    If 1-2 to 1-8 are all set to off, then the printer is set up for parallel printing which could conceivably be the problem.
    Try one at a time in a different position and see what you get. It is slightly unclear on the location of these DIP switches, but i believe you get to them through the base - just pull the end with the cable holes away from the printer and it should snap out (probably worth checking in the top first in case they are obvious)
    If you need more help with this then please ask again - I will keep hold of the manual until i hear back from you, there is little else of much use in it, and nothing that sheds any other light on the problem - I think the DIP settings should help, just make sure you write down what they are set at before changing anything.
    Hope this helps :)
I have an epson tm t81 usb receipt printer and want to connect a cash drawer with the printer for my windows application in vb.net. The cash drawer wont open after the kick there may be some problem with...
Hi!
Are you using the Epson TM-T90 driver? When you go to printer settings through Printers and Faxes there is an option to Open Drawer after or at the Beginning of the transaction.
One other way to check if you have the correct commands for it is by checking on printers Manual and Technical documents of it where you can get online. Click HERE. Register and wait for an Email for Username and password.
Hope this helps.
Jan 05, 2011 | Epson TM T90 Printer
Epson printer just printing question marks
It sounds like it could be a driver problem, try downloading the latest printer driver for your printer from http://www.epson.co.uk/jsps/searchResults/layouts/landingPage.jsp?userQuestion=TM+U210D&_dyncharset=UTF-8&_requestid=391173
If this has helped you then please rate me!
Aug 23, 2009 | Epson TM U210D Matrix Printer
I NEED THE PRINTER DRIVER FOR ePSON TM-P2.01
Driver related problems can be solved by using this program Driver Update (including your epson driver files). Wish you best of luck
Chris
May 12, 2009 | Epson TM-U220 Matrix Printer
Driver TM-L90
Hi...here is the European download page for this model, ...hope it helps!
http://content.epson.de/en/rsd/service/index.1022.htm
Jun 03, 2008 | Epson TM-L90
Found them finally Pete - this is the service manual for the printer; http://www.posguys.com/download/TML90_Peeler_TRG_RevB.pdf Check page 45 of the pdf (page2-21 of the manual) for the location of the switches, the next 2 pages for the settings a bit clearer than on my previous post. also probably worth a read through the rest, in case there are some other possible solutions - I couldn't find one but you might see something that sounds familiar. Hope this helps, still trying to find a user manual direct link, will post it if i find one :)
Jul 02, 2007 | Epson TM-L90
??????????? printer doesn't stop printing, help!
Turn off the printer. Hold down the power on button for 20 secounds. Did that clear it up Pete ??
Jul 01, 2007 | Epson TM-L90
Epson TM-L90 Logo
342 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
