Question about Encore ENHWIN3 Wireless Router
Pin number for encore wireless router model #enhwi-2an3
  • 7,627 Answers
  • 96 Answers
SOURCE: Problem with Encore 802.11n Wireless Router ENHWI-N2
Are you able to access internet when you are connected with a cable netween your laptop/desktop and router please check if yes then with the same connection go to http://192.168.1.1 default username admin and password "admin" and then check in the wireless tab is there any security on the wireless the same code needs to be entered on the laptop also in wirless network connections
Or the issue can be conenctivity between your service provider and router you may need to do some settings as per your service provider on the router for that again you need to open the 192.168.. page
let me know if this help, the below link will help you to check your connection once by one
Posted on Dec 01, 2009
  • 232 Answers
SOURCE: Encore Wireless Router Wireless connection problem
Do you have a key for the wireless? Double and triple check that your typing it correctly and that you have the correct authentication type eg - WEP, WPA, WPA2 etc.
Posted on Dec 15, 2009
govinda123
  • 2263 Answers
SOURCE: how can i put a password on my Encore ENHWI-N2
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Posted on Jan 10, 2010
Geekman
  • 32281 Answers
SOURCE: installing encore enhwi-g2 router wuithout cd rom
You can configure the wireless router from unauthorized access by connect a LAN cable from the computer to the router and open a browser and enter the router's configuration URL IP address.
To secure your wireless network from unauthorized access please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Mar 07, 2010
  • 97 Answers
SOURCE: Is Encore ENHWI-N3 Wireless Router windows 7
You should be fine using it with Windows 7, as there is no drivers as such for the router, you are just using the wireless (or wired) connection to the router, and windows doesn't really care how it gets there. As long as the adapter you are using to connect to the wireless network is windows 7 compatible you should be fine.
Hope that helped!
Posted on Oct 17, 2010
Where can i update drivers for win7 encore enhwi-2an3
There's no such thing as a driver for a router. You have a wireless NIC driver which can be found on the computer manufacturer site.
May 06, 2014 | Belkin (F5D5231-4) Router
Cannot reset encore 3g mobile broadband router and repeater. model type ENHWI-3GN3 N150
To reset ENHWI-3GN Router and repeater press and release this button to reboot the device. Press and hold this button for 10 seconds to load the factory default settings of the system.
You can see this steps in this PDF manual on page 7.
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-3GN3_UM.pdf
Jan 03, 2014 | D-Link DI 514 Wireless Router (DI-514)
I can't get wireless internet on my wireless laptop
What is the laptop make, Model and the OS you are using? Is the wireless router Secured with a SSID and Security Key (password)? When you search for Available Wireless Networks, on the laptop, what is listed? Is the wireless adapter turned on?
Jan 09, 2013 | Computers & Internet
I get dr-655 configuration screen instead of ENHWI-2AN3 screen. Both my router and access point use 192.168.0.1 as the setup screen. how can i access the encore wizard instead of my router page?
Whenever you assign the same IP to the both the Modem and Router, this sort of this happens. In order to access the Modem, you have to either remove the router OR connect directly to the Modem (ENHWI-2AN3) through a patch of network cable connecting the cable at any of the LAN ports (yellow ones) and LAN card of your PC/Laptop.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 11, 2011 | Encore ENHWI2AN3 IEEE 80233u IEEE 80211bg...
Were do I find the pin number on my router to set up up pc I tried all the numbers but the don't work?
Normally the PIN is located on the label on the bottom of your router. Google the brand and model of your router and see if there is an instruction manual available for it. For example search for "Encore ENHWI-2AN3 quick setup"
Sep 07, 2011 | Computers & Internet
What is the device password for encore wireless-N router ENHWI-2AN3? I cannot connect because of this device security password. It says that i should see it on the device or any printed information but i...
normally the password is in BACKSIDE of the device, or in the users manual. But, sice i have the same router, the username password combo is; username : admin password: admin
Apr 06, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
I forgot the router 8 digit pin number of ENHWI-2AN3 (ENCORE)?
At the bottom of the router you can find the 8 digit pin code
Sep 27, 2010 | Computers & Internet
Installing encore enhwi-g2 router wuithout cd rom
Mar 07, 2010 | Encore ENHWI-G2 Router
Encore ENHWIN3 Wireless Router Logo
133 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
