Question about Dehumidifiers
BD20S-CN dehumidifier making loud rattling noise.
Coming from bottom, right, under the casing /only when compressor is on. Louder if I push down on machine. Stops when I push UP on the casing (on underside). New machine.
IrishDruid
  • 2712 Answers
SOURCE: Dehumidifier seems to not be dehumidifying
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Posted on Jun 11, 2008
  • 41 Answers
SOURCE: Maytag Dehumidifier
the clicking is the compressor over load safty switch. possably start componets or compressor motor not good eather way dan
Posted on Jul 17, 2008
SOURCE: My Kenmore 54701 Dehumidifier makes a loud noise
the dehumidifier hums ans fan does not turn
Posted on Jan 25, 2010
SOURCE: Kenmore dehumidifier M/N 580.53650200 only runs for about 1 min
Well to knowledge the problem 40 percent is dry. means your basement is great. humidity should be 30/50 percent 50 grows mold. also if it runs for a min the auot shut off is activating. check this first.
Manifestr
Posted on May 02, 2010
  • 449 Answers
SOURCE: The dehumidifier is making a
your fan is possibly hitting something didyou drop it or bang into it you should have some one like a tech. to checkit out and PLease stop using it till you do this you could be damaging this unit even more than it allready is
Posted on Aug 19, 2010
Noise
There are basically two moving parts, the fan and the compressor. It more then likely is the fan. Be sure the air path is clean and the fan blade does not hit anything. If it is the compressor I would suggest getting a new unit and using that one elsewhere for the short time it has left.
Apr 22, 2014 | Haier 65-Pint Dehumidifier
I have H. Bay model HB40F dehumidifier. It does not seem to ever actually start the compressor. There is a plastic box on the side of the compressor that contains a couple of coily looking things. It...
It is probably the start device(the coil looking things), as long as you don't hear the compressor humming. A loud hum is a lock compressor and the cost would be far greater than a new unit.
Jun 17, 2011 | Soleus Dehumidifiers
Bucket rattles loudly and compressor buzzes
Sounds like compressor is having trouble starting not much can be done with dehumidifiers because not many people work on them and they are very cheap to replace. Replace dehumidifier its not worth time and money cut you losses. If this helps please rate me and do a testimonial.
May 21, 2011 | Kenmore 54701 Dehumidifier
The dehumidifier is making a loud noise. The noise gets louder when the fan speed is increased. What is the problem?
Aug 19, 2010 | Maytag M7DH65B2A Dehumidifier
Whirlpool dehumidifier makes a lot of noise when running and vibrating, dehumidifier is only 4 years old it does take out the water but very noisey any way to quiet it down?
When the compressors start to go bad they often start to get very loud also...the cost to replace the compressor will probably be more then a new unit...
Also check out this tip about dehumidifier problems...
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
May 02, 2010 | Whirlpool AD50USS Dehumidifier
Engine is making notice
The compressor is a mechanical pump that will be loud...plus the fan has to move air to make it work correctly...not much you can do about it...
heatman101
Apr 03, 2010 | LG Goldstar LD65EL Dehumidifier
Motor makes noise
heatman101
Feb 15, 2010 | Kenmore 54701 Dehumidifier
When running load noise coming from black cylinder
That part you identified is the compressor of the dehumidifier. Compressor is probably bad or going bad. When compressor go bad the valves start making noise and they lose alot of there efficiency.
Dec 10, 2009 | LG LHD65EBL Dehumidifier
LG LHD65EL Dehumdifier Fan Noise
It sounds like the fan has etached from its hub. This usually is not repairable if that's the case. Replace the fan.
Jul 03, 2009 | LG Goldstar LD65EL Dehumidifier
LGd45el dehumidifier motor cycles on and off
dehumidifier motor making rattle noise
Apr 02, 2009 | LG Dehumidifiers
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
