Question about Sharp Viewcam Vl-h860u Hi8 Camcorder - Transfer Old 8mm Tapes To Dvd Or Pc
I NEED A AUDIO/VIDEO CABLE QCNW-1906TAZZ and how much
I lost my cable so I can watch my movies on the TV
2 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: audio
If you mean an RCA connection, color red,yellow and white both ends, you can by at any electronics store in your area. If it is other connection you connect or attach converter.
Its pretty if you can show me a pic of the slot hole in the tv and audio input.
may this help,
melnavz
PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Apr 25, 2008
Cannot watch tv and listen to the cd player at same time. is it my connection? Yamaha rxv 665
If the TV is completely routed through the reciver (audio and video), well that's how it works. One source at a time.
This is yet another reason why I highly recommend against routing video through and avr and audio through a TV. Unnecessary commitment of resources that have no need for each of them.
I would run analog audio and the best quality video directly from the cable box to the TV; then the best quality Cable Box audio to the AVR. That way you can have awesome audio for movies bubt lo-fi TV-only audio for the Weather Channel (and you could still tinker with the CD or whatever at the same time).
Feb 11, 2011 | Yamaha RXV665BL Receiver
While watching netflix movies through internet TV widget I am still hearing the audio from the current channel the cable box is on, how do I eliminate the audio coming from the cable box and get the...
Just turn off the cable box,when u used the TV widget to watch the Netflix movies online.So u,will not have anymore audio signal interference.
Oct 12, 2010 | Televison & Video
Back ground music louder than voices watching movies on cable
Is this a new problem or always like this? <<<<<<<<
What is your speaker complement? The center usually carries the dialog.
Are the receiver and its speaker systems set up per the manual? Make it so.
How is the TV-related (Cable) audio entering your receiver? It SHOULD be from the cable box, digitally if available, NOT the TV. You don't need a Low-Fi middleman handling your audio.
Mar 05, 2010 | Denon AVR-3805 Receiver
Laptop to tv
Your model laptop has S-Video out capabilities. Depending on what model TV you are connecting to, you would then need an S-Video to (whatever input connection your TV supports: S-Video, VGA, RCA, HDMI) cable. Once you have the cable connected, set your TV to the input method for the cable used, and press Fn + F4 on your laptop Keyboard to project the image over. May need tp press more than once depending if you wish to only display on one screen or both. S-Video is only a video out cable, so you will alos need to run an audio connector cable from your laptop to TV as well, or just use a pair of external laptop speakers for your sound.
Jan 12, 2010 | Computers & Internet
How do I get the "Watch Instantly" feature to play on my TV? Do I have to have my laptop hooked up to it while the movie is playing? Also, is there a way to save these movies to my Tivo so that I can watch...
Sounds like a netfilx service your using? Yes the laptop will need to be connected to the TV, Now if you want to save to pvr I would suggest you get a ROKU box www.roku.com there about 100 bucks wit hthis you can save to a tivo and more!
I hope this helps please do click the accept button for my efforts/
Dec 29, 2009 | Televison & Video
My new universal remote
Jo have you plugged in the Audio and Video cable in correctly. You need to check that the Video cable is in the corresponding input on the TV
Jun 08, 2008 | RCA Universal Remote Control
How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Mar 04, 2008 | Panasonic SC-HT680 System
Sanyo TV
If I understand your posting/description right, you have:
1, a Sanyo TV with only 1 video input;
2. you have a DVD player with only video output; and
3. you have a VCR (which I will assume to be with both video input and output).
Your query, if I may clarify, is how to hook them up so that you need not connect/disconnect any video cable when you want to switch video source from either DVD or VCR.
If that is what you want, then connect:
a. audio/video OUT of your DVD to audio/video IN of the VCR;
b. audio/video OUT of your VCR to audio/video IN of the TV.
The above described connection would allow you to:
i. watch DVD movies on your TV (your VCR must be powered ON and set to Video INput, your TV must be powered ON & set to Video INput);
ii. watch tape movies from your VCR without disconnecting/connecting cables.
Additionally, this arrangement would allow you to record DVD movies in your VCR. Further, connecting your cable/aerial to the RF INput of your VCR would allow you to do the same with a TV/Cable program.
Incidentally, if one of your units (TV, VCR, DVD) would only have a single audio input, it is still possible since some models uses the white audio RCA connector as either left or mono, the red is right. You can also use a 2 female RCA to 1 RCA male adapter as shown below to joint the red/white audio.
Hope this be of some idea/help. Pls post back how things turned out or should you require additional information.
Good luck and kind regards.
Nov 19, 2007 | Sanyo DS32224 TV
Blue Box in the Corner won't turn off!
That problem might be on the remote of display settings on video display. There is one button that will turn that off. Try Display Settings
Nov 13, 2006 | Zenith SY2765S TV
Sharp Viewcam Vl-h860u Hi8 Camcorder - Transfer Old 8mm Tapes To Dvd Or Pc Logo
102 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
