Question about Ovens
Can't turn off auto on fisher and paykel pepper oven
Fisher & paykell pepper
SOURCE: Fisher and Paykel electric cooker (Pepper)
No, it's the first 2 buttons on the left pushed together as well as the + or - to set the right time
Posted on Jul 16, 2009
kojak18
  • 31 Answers
SOURCE: My Fisher & Paykel Paprika oven has
check the ignitor and the oven thermost. the oven control board may be out.
Posted on Jun 22, 2010
tbirdfan1
  • 3051 Answers
SOURCE: F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
  • 1514 Answers
SOURCE: I have a fisher@paykel schott
You need to give the model number to get exact instructions. On most Fisher & Paykel ovens there is a button with a picture of a hand over it. You press this button to take it off auto. I expect if yours is new it will be the same. If you need a user manual you can get one in Adobe Reader format from http://www.fisherpaykel.com.au/customercare/userguide/index.cfm
Posted on Sep 25, 2010
KevinWhite
  • 1902 Answers
SOURCE: Fisher & Paykel double wall
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Feb 03, 2011
F & P Pepper stand alone oven. How do you get the top element plates out to clean them properly?
You can't they are permanently wired in. They swing up so you can wipe out the drip bowl.
Aug 25, 2016 | Fisher and Paykel Ovens
How do I turn off Auto on oven
Hi Anita,
A quick search of Google for an answer to my question "Turning Auto Off on a Fisher and Paykel Oven"
With little more detail from you like model and if AUTO Off as with Timer I could pin point it, i..e.be more accurate.
So if my guess is correct than it should be on the Analogue/Analog Timer Knob OR if electronic somewhere on the keypad, electronic touchscreen? pad....meaning set it to MANUAL....have you tried that?
Cheers
Nov 02, 2014 | Fisher and Paykel Ovens
How do I replace the fan in a Fisher & Paykel 60cm oven
ill assume your referring to the cooking fan you see inside the oven and not the outer cooling fan, you will need to turn the breaker off outside to cut power to the oven then you will have to take the oven out of the wall and remove the back cover then its normally just 3 screws and the nut on the inside of the oven that holds the fan blade on (which is reverse threaded by the way) and it should come out
Sep 27, 2014 | Fisher and Paykel Ovens
I have a fisher & paykel Astro built in wall oven which has a problem, after using the oven and then turning both switches off for some reason the rear element continues to stay on and will not switch...
Hi - theres a few components that may well cause this to happen - the power module which controls the heating & fans etc - isolating relay which switches the heater & fan relays - it only avctivates when a cook mode/cycle is selected.
One of the two components could be faulty - I guess a sparkie or techie may be your best option..
Aug 07, 2011 | Fisher and Paykel AeroTech OS302 Electric...
I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
Jul 01, 2011 | Fisher and Paykel Ovens
I have the fisher paykel pepper electric stove top and oven at home. the stove is working just fine, but below it the oven turns on but it doesnt heat up. what should i do?
When you say that the oven turns on I assume that the oven indicator light is working. If this is so there will be only two likely causes for the oven not working.
Oven element is faulty - check by performing continuity test;
Wiring at oven element terminals burnt off - check visually.
If you are handy carry out the above. If not, call a repairman.
Feb 15, 2011 | Ovens
How do I reset the oven on my fisher & paykel Oregano after a power cut?
kiss. first check the auto clock is set corectly
reset it my one asks you to hold 3 buttons down at the same time then it resets and you can set the time again..
if you stuff it up just start over. if that dose not work call a servise man nfor advise
Jul 25, 2010 | Fisher and Paykel Ovens
hELLO THERE:
Jul 14, 2010 | Fisher and Paykel Ovens
Fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Nov 12, 2008 | Fisher and Paykel AeroTech - OS302M...
Pepper Oven overheats
This problem is caused by a faulty thermostat controller. This is the dial that you use to set the temperature for heating.
Jun 17, 2008 | Fisher and Paykel Ovens
Ovens Logo
79 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
