Question about American Standard 2045.013 Fontaine Pressure Assisted Flush Toilet
I own a bone-colored American Standard Fontaine 2006-30 1-piece toilet which (matches my bidet) has a push button flusher. It no longer works and plumbers can't find parts in Toronto, ON. It never really flushed that well from the beginning. I live in a condo..and don't mind buying a new toilet, but want one to match the bidet? Can you help me?
4 Suggested Answers
djchillsnyc
  • 151 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
r_b03
  • 102 Answers
SOURCE: My toilet doesn't flush every
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Posted on Jun 17, 2011
American Standard Carlyle Series toilet is refilling about 10 percent of the water in the tank every 20 minutes. Do I need to replace the flapper or the entire flush valve?
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
Sep 20, 2013 | American Standard 2004.014 - Champion...
Tilche seat
contact american standard or a local plumber wholesaler
Jul 18, 2013 | Crane Plumbing Toilet To Go Tall...
I need a new toilet seat for EL 270 American Standard Ellisse elongated toilet in shell color
Depending on whether "shell" is a descriptive term, or the actual color, these guys have some Elisse seats: http://www.plumbingsupply.com/toiletseats_american_standard.html
Jul 20, 2011 | American Standard Church Seats EL270...
Need to replace toilet seat and cover for a Williamsburg, white toilet. The part number I have is 5395.700.....but I have learned this number no longer exists. What number toilet seat/cover fits a...
Your toilet is still offered by the manufacturer:
http://www.americanstandard-us.com/toilets/williamsburg-one-piece-elongated-toilet/
Available replacement toilet seats from American Standard can be seen and ordered here:
http://www.americanstandard-us.com/repair-parts/toilet-seats/
You might consider finding you nearest dealer or choose another on-line retailer:
http://www.americanstandard-us.com/dealerLocator.aspx
Before ordering suggest you confirm with American Standard Customer Service the appropriate replacement seat for your model.
http://www.americanstandard-us.com/customerservice/onlineStoreSupport.aspx
Mar 15, 2011 | American Standard Williamsburg Toilet Seat...
I recently bought (9 months ago ) an american standard brand model CADET 3 one piece unit and recently 1 month ago , after flushing the toilet the water fills the up the water tank but there is...
theres probably debrie in flush valve, mite also try putting food dye in tank (any color) if it appears in bowl the flapper is seeping water and activating flush valve..
Nov 21, 2010 | American Standard Cadet 3 Right Height...
I seems that the williamsburg 5395.700.20 toilet seat is no longer made. What can I use as a replacement
If it doesn't embarrass you, you could take the two nuts off the bolts holding the seat on, put the seat in a bag and take it to a Home Depot or Lowes or Walmart etc and match a new one to your old one. Good Luck
Mar 07, 2010 | American Standard Williamsburg Toilet Seat...
Not flushing
take the lid off the tank and make sure that the chain is still conected from the flusher handle at the top of the tank to the plug at the bottom of the tank
Dec 09, 2009 | American Standard 2002.014 - Champion4...
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
American Standard 2045.013 Fontaine Pressure Assisted Flush Toilet Logo
57 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
