Question about Hoover Dryers
Model 5030D fan belt replacement
  • 314 Answers
Instructions
Unplug the electrical cord of the dryer from the electrical outlet before attempting to fit a new belt on the dryer.
Remove the lint screen from under the lint screen cover and locate the screws that are underneath the cover.
Unfasten the screws with a screwdriver and remove them from the lint filter slot, setting the screws aside.
Place a putty knife between the top and the cabinet on both sides of the dryer near the front, lifting up to dislodge the lid from the plastic clips that hold the top down.
5
Flip the top back toward the back of the dryer and let it rest against the back wall.
6
Locate the front kick panel and slide the putty knife just behind both sides of the panel, pulling forward to unfasten the panel from the plastic clips. Move the panel out of the way.
7
Locate the screws that hold the front panel on the dryer cabinet at the top on the inside of the cabinet. Remove the screws using a screwdriver.
8
Unfasten the electrical wire connector by hand, pulling it straight out from the back of the front panel. Move the panel out of the way.
9
Place a couple of wood blocks under the front of the dryer drum to support it while you are removing the old belt. The drum is the cylinder that holds the clothes as they are drying, located just behind the front panels.
10
Push the idler arm forward just a bit to relieve the tension on the belt, and slide the belt off the idler and motor pulleys. The idler arm is located next to the motor near the back of the dryer and has a pulley on a metal arm with a tension spring attached to it.
11
Lift the drum up off the blocks just a bit, slide the old belt off of the drum, and take it out of the dryer cabinet.
12
Hold the drum up just enough to slide the new dryer belt around the drum and fit the belt into the V-slot in the center of the drum, laying the remainder of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
13
Loop the end of the belt around the idler pulley and over the motor pulley, pushing back on the idler pulley to release the tension on the belt.
14
Let the idler pulley move back into place and check the alignment on the belt to verify that it is seated properly on the drum and the pulleys.
15
Remove the wood blocks from under the drum when the new belt is installed and attach the front kick panel to the dryer cabinet, pressing the panel onto the plastic clips.
16
Place the front panel over the kick panel and attach the electrical wire connector to the back of the panel by hand, pressing the connector back over the electrical prongs on the back of the panel.
17
Attach the screws at the top of the front panel on the inside of the cabinet with a screwdriver. Lower the top of the dryer back down over the cabinet.
18
Press the top of the dryer down over the plastic clips until the lid is secure and fasten the screws on the inside of the lint filter cover.
19
Slide the lint filter into the lint filter slot and plug the electrical cord of the dryer into the electrical outlet.
Posted on Jan 10, 2013
There are other question and answers about Hoover dryers model 5030D in the related questions section
?????? ???????? ??????? ???? ???? ??? ??? ???? ??? ????? ??? ?????? ?? ????? ?????? ???? ???? ?????? ????? ????? ??????? ???????? ??? ?? ???? ?????? ?????? ??????? ???? ???? ??? ???? ??? ??? ???? ?????? ??? ???? ???? ?????? ??????? ??????? ????? ????? ??????? ????? ????? ???? ????? ??????? ??????? ???? ?????? ????? ?????? ??????? ? ???? ????????? ???? ???? ????? ????? ??????? ?? ????? ?? ???????? ???? ???? ?? ?????? ???? ????? ??? ??? ??????? ???? ??? ???? ???? ??? ???????? ?????? ????? ????? ?????? ?????? ???? ?? ?????? ??????? ???? ?????? ????? ????? ??????? ???????? ?? ??????? ???? ?????? ????? ????? ????? ???? ??? ???? ????? ????? ????? ?? ???? ??? ????? ?????? ?????? ????? ???? ???? ?????? ????? ???? ??????? ???? ???? ?????? ?????? ????? ? ??? ???? ????? ??? ??????? ????? ???? ??????? ??????? ????? ????? ???????? ???? ?? ?????? ?? ???? ???? ??????? ? ??????? ???? ???? ??? ???? ???? ??? ???? ???? ????? ??????? ???? ???? ???? ???? ???? ?????? ????? ???????? ??????? ???????? ? ????? ????? ??????? ???? ?????? ????? ????? ?????? ???????? ???????? ??? ???? ???? ??? ?????? ?????? ???? ??????? ?????? ? ?????? ???? ???? ????? ??? ??????? ????? ??? ??? ???? ???? ???? ?????? ?????? ?? ?????? ????? ????? ???? ???? ??????? ???? ???? ????? ????? ??????? ? ???? ???????? ??????? ???????? ???? ??? ???? ????? ??????? ???? ???? ?? ????????? ???? ???? ??? ??? 99% ???? ????? ????? ???? ????? ?????? ??? ???? ??????? ???? ??? ?????? ?????? ??????? ?? ?? ????? ????? ???? ?? ???? ????? ???? ???? ??? ?????? ?????? ????? ???? ???? ???? ??????? ?????? ?????? ?????? ?????? ? ???????? ??????? ???????? ??? ???? ????? ?????? ????? ????? ?? ???? ?????? ?????? ?????? ??? ???? ????? ???? ???? ????? ????? ???? ???? ??? ???? ??????? ???? ??? ??????? ?????? ??? ?????? ??????
Feb 11, 2016 | Hoover Dryers
Fan won't work
It can be issue with faulty motor or its faulty fan control relay.
Bother are to be inspected.Test volt at fan relay and fan motor.-------------
For more help,i suggest you to go through the troubleshooting links mentioned below:-----Click the link below:------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
------------These will help.Thanks.
Nov 27, 2012 | Cars & Trucks
Hoover 5030d dryer I have to spin the drum to let dryer work. What is the problem? Where can I find the spare part?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 07, 2011 | Dryers
Hello, i have a hoover dryer, model 5030D, secondhand, it is just been purchased my us. we put on our first load on and the machine stopped within 15minutes. we noticed then that the machine was...
Hi, if I remember correctly this model originally came with 2 faceplates so the controls can still be easily accessed, when the dryer was installed upside down on a wall. Most dryers can be run upside down, or even on their side as I done in the past with my Hoover 5030D, so the problem would lie elsewhere.
Dec 26, 2010 | Hoover Dryers
Drier
I just saw this model advertised in Australia online and they said, less than a year old!
model 5030D???????????????????
I would not buy a used appliance!
Just putting good money into bad. Unless I can afford to fix it.
And I f so I would be better buying a cheap new one and take the extended warranty in today's market.
But everyone's not me!
Huuum
Sep 23, 2008 | Hoover Dryers
I have a Hoover 5030d & its making a noise as the barrell turns. If spun manually it sounds a bit like a bearing. Is it easy to change a bearing on a Hoover 5030d?
It sounds like the engine shaft bearing. Fairly simple to fix or replace with the correct tools and know how.
Be sure to take photo's of the motor, tension arm, and any wiring.
You'll need pliers to remove the clamp from the fan, then remove the belt from the motor and make sure that's were the problem is before going any further.
Jul 06, 2008 | Hoover Dryers
Hoover Tumble Dryer 5030D
I picked up a second hand unit which had the same problem.
I removed the back (philips head srewdriver and 1/4 in socket) and vacuumed all the lint from around the motor, and the vent at the back.
The motor drops our easily for cleaning (1 screw). Make sure the belt tensioner goes back in the same slot.
Mine now works as normal.
May 18, 2008 | Dryers
Dryers Logo
205 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
