Question about DeLonghi EC Coffee Makers & Espresso Machines
Lights are flashing on my DeLonghi ec820 coffee maker
5 Suggested Answers
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
SOURCE: My DeLonghi DCM485 coffee maker
The same thing happened to me....At least you got three years out of yours, I got three months.
Posted on Sep 11, 2008
SOURCE: User Manual required for a DeLonghi EC410 Coffee Maker
http://www.delonghi.com.au/products/product_details.asp?Model=EC410&archives_srch=true
x
Posted on Jan 18, 2010
  • 5 Answers
SOURCE: DeLonghi BCO120T coffee maker side does not work.
TYPICAL FAILURE OF THIS MACHINE = THERMAL FUSE MALFUNCTION.
WHERE ARE THE THERMAL FUSES: There are 2 thermal fuses under the coffe tray and 1 fuse under the espresso boiler. (YOU WILL HAVE TO REMOVE THE BOTTOM COVER OF THE MACHINE). What this fuse does is regulate the temperature of the heating element so that everything doesn't melt (yep, I tried to bypass the fuse and found out the hard way..testing...testing..). Anyway, replacement for these thermal fuses are sold at RADIO SHACK for about $2.00. (Yep, only $2.00) If you open the bottom cover of the coffee maker and you will see the 2 fuses, they look like resistors. they are covered in a plastic tube to prevent damage. Clip them off I used a small wrench(radio shack) to pry open the small clamps that hold them, replaced them, then reclamped the new fuse back on.
REPLACEMENT FUSES: The thermal fuses have the watts/Amps and temperature stamped on them. There is 1 part that I use and has been working well for over a year ( over a year, yes this machine can last a long time!!).
The part # is Labeled - Raido Shack 270-1321 Thermal Fuse 438°F (226°C) 250VAC 10A (For heating devices like coffee makers and hair dryers). The temperature may vary + - a few degrees° on the label, from what I have seen.
HOW TO TEST THERMAL FUSES: These fuses are not only used for temp control but they also close the curcuit. If the fuse blows then it is open and will not heat. I use my ohmeter (put 1 prong at each end of the fuse) and if it reads open it means that the thermal fuse is bad, it has blown, there is no current running through it. I believe a light meter can check for continuity also and are much cheaper. Test by putting the test leads at each end of the fuse (1 prong at each end).If the light turns on then you are good, getting continuity. If you cannot get no light then it is bad. You can test your light fuse with a simple wire, touch each end and the light should go on, cut the wire in the middle and no light!!easy.
fyi. If your coffee does not get hot enough the fuse may need to be replaced also.
HOW TO READ THE OHMETER.
Know that a reading of OL means "over limit." That means the resistance is off the charts, and you have a break in the circuit. If you got an OL reading for the plug wires, you'd know there was a broken wire that needs replacing. In this case, we got an OL reading because the light switch is in the "OFF" position.
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwX1LcJD
Consider that a low reading, anywhere from 0 to .5, indicates very little to no resistance. This means there's a continuity of current in the circuit. This is the reading you should get
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwXjz6C0
Posted on Sep 30, 2010
My Delonghi Magnifica has a problem after turning on it doesn't get hot and after a while of the cup lights flashing the red warning light comes on and the machine won't do anything!!
most coffee makers have a temperature sensitive diode in the circuit, and that will "blow". if you are comfortable working on your own unit you could troubleshoot it, otherwise, bring to a repair shop.
Jun 10, 2016 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi EC 820B leak from the bottom edge of the Boiler outlet/ Infusion assembly.
the hose has become clogged up with deposits and split.. you can try to take apart and repair yourself or look up your local shop for repair
Jun 10, 2016 | DeLonghi EC820.B Black Pump Espresso...
How do i decalcify the unit?
de-scale solution available from most coffee machine retailers.
Sep 19, 2009 | DeLonghi CAFE DUO Dual Drip Coffee Maker
Coffee Makers & Espresso Machines Logo
643 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
