My fridgidaire won't final spin Model # FTF530FS0
  • 176 Answers
SOURCE: wont final spin , had loud knock but quit
You have a broken shock absorber and you need to relpace it. Remove the lower inspection panel by unscrewing the 2 screw at the bottom of the panel below the door. Remove the panel and look inside on either side of the wash tub. You will see the 2 shock absorbers and one or both will be broken. There are 2 plastic pins holding them in place. On the pointed end of the plastic pin, there is a tab that needs to be depressed (use a flat screwdriver) so that when you pull on the other side with a plier, the pin will come out. Go buy the replacement shock absorbers at your local appliance shop. To install, put the absorber in place and push in the plastic pins. Make sure the correct end is up. Replace the front panel and the job is done.
Posted on May 24, 2009
Jahn27
  • 1554 Answers
SOURCE: model fwt645rhso will agitate but
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Posted on Jun 18, 2011
SOURCE: the fridgidaire fron load washer model FTF530FS0
washer is banging loud when spinning
Posted on Jun 27, 2011
  • 6277 Answers
SOURCE: FRIDGIDAIRE MODEL # FTF530FS0 -
(Start by this!)
I always recommend buying a replacement as belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person (assuming a front loader!):-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 12, 2011
  • 389 Answers
sorry have not come across that model its not within my expertise
Posted on Nov 15, 2011
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Won't final spin ?
What is the model number of your unit?
Nov 04, 2012 | Washing Machines
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Final spin won't go through... makes a squiky noise and no high speed spin
first how old is your machine. second is it under warranty? third have you tried to spin in all selections to see if your timer is working?
Dec 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Wont final spin
Nov 14, 2011 | Washing Machines
FRIDGIDAIRE MODEL # FTF530FS0 - SERIAL # XC70213167 . BELT KEEPS COMING OFF?
(Start by this!)
John C
Aug 12, 2011 | Washing Machines
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
