Question about Nikon COOLPIX L20 Digital Camera
Nikon coolpix L 20 26164 needs door spring repair again
I purchased this camera at Radio Shack. One year later the door spring stopped keeping the door closed. I had it serviced. It is one year after fixing it and the door is failing again. Now I have to pay more than I did for the camera to get it fixed. Nikon says they do not replace cameras, only repair.
    Sergeant:
  • 321 Answers
Replace the body
Posted on Jan 10, 2013
IKnow
  • 68 Answers
SOURCE: nikon coolpix s3 black screen
I agree with you, although I would not rely on Kodak. I find their digital products don't stand up to much. Based on what I see come through my digital lab, I recommend Canon, Casio and Sony
Posted on Jan 16, 2008
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Posted on Mar 26, 2008
praky16
  • 744 Answers
SOURCE: flash on Nikon Coolpix s200 camera not working
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Posted on Jun 28, 2009
SOURCE: Out of memory on Nikon Coolpix L18 camera
I noticed that, after dumping the full SD card onto my computer, I didn't seat it perfectly back in the camera (my finger bottomed out on the batteries before the memory card 'clicked' into place. With the camera unable to see the SD card, it defaulted to the internal memory, which is very small.
I got the SD card seated fully and the "Out of Memory" message went away.
Posted on Nov 14, 2009
  • 11967 Answers
SOURCE: My Nikon Coolpix s200 digital camera has a lense error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 03, 2009
Nikon coolpix s80 won't charge
If its under a year old, you should be able to take it back to the vendor for replacement or repair under warranty. You'll need a proof of purchase.
Mar 03, 2012 | Nikon COOLPIX S80 Digital Camera
I bought it last year, but now it seems there is a problem with charging the battery. It only charges about 22 seconds then it stops, I have to keep eyes on the camera when it is charging, when the green...
It sounds like the battery is damaged and needs to be replaced. If it charges far too fast and discharges far too fast, a few of the cells within the battery may be dead.
You can get something like this from Amazon:
http://www.amazon.com/Hi-Capacity-Equivalent-NIKON-COOLPIX-Battery/dp/B003AX3PQK
Mar 11, 2011 | Nikon COOLPIX S8000 Digital Camera
My Nikon Coolpix S570 has a purple and black striped screen and I can't take pictures but everything else on the camera comes out clear. I can read the menus and I can see any previous pictures perfectly...
Your camera has the classic and unambiguous symptoms of a failed CCD imaging sensor. It's a common fault with all digital cameras but apart from when there's manufacturing faults should not usually occur until a camera is five to six years old.
There is nothing which you've done to cause the fault, nor is there anything at all you can do to fix it.
The only fix is to have it replaced, but it's not a DIY job and the part is not cheap. However, your camera is probably less than a year old so should still be under warranty; if you purchased it in Europe from an official supplier then you have a two year Nikon warranty. To make a claim you'll need to visit the Nikon website in your country and complete a repairs form which you send with the camera along with copies of any proof of purchase required. Without proof of purchase the repair is chargeable.
After repair, check the images carefully, looking for any marks on the images which are in the same place on every shot: these may be quite subtle such as a slightly blurry small patch or two (almost like an out of focus water droplet). If you have any of these symptoms then promptly return the camera to Nikon to do the repair again as it's not uncommon for a clumsy repairer to leave debris or even adhesive/grease on the sensor. If these faults go unnoticed then most manufacturers try to wriggle out of responsibility by claiming the repair only had a ninety day warranty.
Mar 11, 2010 | Nikon COOLPIX S570 Digital Camera
The latch on the battery door of my Nikon Coolpix
You can get that replaced or repaired thru the list of Nikon Authorized service centers near you area. Just click the link::
http://www.nikonusa.com/Service-And-Support/Nikon-Authorized-Repair-List.page
Hope this helps.
Dec 29, 2009 | Nikon Coolpix L11 Digital Camera
I have bought 3 cool pix cameras for my daughter. all three are less then a year old with one only being a few months old and all three have lens problems. i dont know what to do with them or where to take...
Under consumer laws they should exchange them or put you in touch with Nikon to send them back for repair.
If Radio shack won't help you then get in touch with Nikon here >>>>>
http://www.nikonusa.com/Service-And-Support/index.page
All three of the camera's should be still under the manufacturers warranty provided you didn't buy them second hand.
You may need to provide proof of purchase when contacting Nikon.
Good luck.
Nov 12, 2009 | Nikon COOLPIX L4 Digital Camera
Nikon COOLPIX S5 is not turn ON
It's Hannah again. I took my Nikon Coolpix S5 camera to Nikon Hong Kong Service centre and after they had a preliminary look at it, they told me that the IC (or whatever) in the camera has probably burnt out and that it would cost about USD120 to repair the camera. USD120!! -----heck, it would be cheaper to buy a brand new one here in Hong Kong since this model is already out of fashion! I really wonder if this quoted repair price is a rip-off or is just another way of saying, "Throw the camera away and don't waste time repairing it!" Advanced technology, dependability, reliability, save the environment, blah, blah, blah,.....my foot! I'll never purchase a Nikon prouct ever again!!
Jul 04, 2008 | Nikon COOLPIX S5 Digital Camera
Battery door and latch broken
Have used a 5-cent nylon cable tie for years on our CoolPix 990 and it never has failed, and still allows for battery changes. Looks a little funny to some, but is very functional. Don't know if your camera's design is similar enough for this to work, but it may worth trying.
Oct 29, 2007 | Nikon Coolpix 3200 Digital Camera
Oct 15, 2007 | Nikon Coolpix 3200 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
54 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
