Question about Intel Motherboard
Blank monitor on startup
Hi, I have just built a new PC and the monitor won't activate on startup to allow me access to BIOS setup.
Motherboard details are: Gigabyte GA-MA7790x-DS4
Graphics Card: Gigabyte GV-N95TOC-1GH
CPU: AMD Phenom X3 8750
The Graphics Card is the only expansion card and I have 2 SATA HDD connected.
Do you have any suggestions?
  • brett_kenned Jan 21, 2009
    Thanks for your help guys, tried all suggestions with no luck unfortunately, but had me troubleshooting until I eventually found the separate ATX 2x4 power was not connected. Did not know I had to do this as my 6yo MSI board did not have it (only a 2x10). Cheers.
  • Thomas F. Schneider May 11, 2010
    Disconenct one of the Hard drives. Have only one stick of RAM installed.
    Genius:
  • 1,102 Answers
Make sure the video card is secure
and monitor plugged in properly
does it shut down or you just get a black screen.
you can remove the card and if you have a different slot use it
then restart and see what happens
also are you saying you have dual harddrives
Posted on Jan 21, 2009
None of the keys work on hp logo screen F10, f11. f9. esc system won't boot from hard drive or cd
are you using a usb keyboard? A lot of systems require a ps/2 (purple round connector) keyboard to access the bios settings and anything on the startup screen unless you have set usb on boot in the bios settings. I would try connecting a ps/2 keyboard and see if it helps.
May 06, 2011 | HEWLETT-PACKARD Pavilion Desktop with AMD...
I have a dell dimension e521 when i turned it on the power light was amber i removed the battery from the motherboard and memory then replaced them it light powered up green with a beeping sound fan came...
OK you have to re-setup your BIOS get into your BIOS and select "Default Configuration" and save then reboot. This MAY get you back. Removing the battery is NOT a great idea unless you have a specific thing to do with the BIOS. If you have a manual you need to read the section on your BIOS and the correct settings to make it function, removing that will "Reset" all settings to blank. Accordingly the PC must be set up all again, as if it just built.
You didn't indicate why? you did this?
Feb 17, 2010 | Dell Dimension E521 PC Desktop
Got a new monitor but need to turn off internal video thats on the motherboard its a p5gd1vm from asus
Access the BIOS settings (you'll see a message on which key to press to access your BIOS setup when the PC boots up) and you'll be able to access the internal video options.
Sep 10, 2009 | ASUS P5PE-VM Motherboard
USB MOUSE x PC BOOT
Could be a problem with your system BIOS, enter the setup while your computer is booting (before it gets to windows) by hitting the F12 key probably. Make sure that the boot order is HDD first, not something else.
Aug 31, 2009 | Laser LX710 Keyboard and Mouse
Lg w1934-bn blank screen after start up, power light on . same problem occurs on different computers used.
Reason 1: Wetness The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
i think this will help.
please rate my solution.
have a nice day.
Jul 05, 2009 | ViewSonic 17" 1280x1024 TFT-LCD/ Speaker...
IBM Thinkpad has black screen with a lock icon
When i got black screen on my Windows 7 laptop when started pc, Windows Boot Genius helped me fix problem without data loss easily!
Jun 08, 2009 | IBM ThinkPad T23 Notebook
Pc monitor blank
Perform a system restore to see if it will restore your settings.
May 12, 2009 | EliteGroup GF8200 MCP78S AM2+ Atx 32GB...
Stand by mode
Check the display cables , and if you have one test a different monitor on your computer.
If this is not a sceen problem, then it is an internal fault possibly the motherboard.
Try first leaving the PC power cord unplugged for ten, fifteen minutes and check if PC restarts afterwards.
Nov 28, 2008 | Computers & Internet
Motherboard graphics card not working, trying to install MicroStar G4MX420D nividia
Can you get into the BIOS setup? Usually, it will say "For Setup Press Fn" when you start booting up. When you get into the setup, look for a menu item that deals with "onboard video". Set it to disable. Then "Save and Exit" the BIOS. The new video board should allow you to view the screen, at a reduced resolution, until you load the new software.
Oct 15, 2008 | Computers & Internet
ATI Driver problem?
Does it have on board graphics(built into the motherboard) If you are trying to install a different video card, then you need to set it up.
Hook the monitor up to the old one with the new one plugged in
Look on the screen on startup for a SETUP or BIOS button(Usually F1, F10, or DEL) then go to ADVANCED and look for anything having to do with VIDEO, then if it gives you a list, with the new card listed, choose the new one. Then restart with the monitor hooked up to the new card.
Feb 24, 2008 | Computers & Internet
Intel Motherboard Logo
113 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
