Question about Porter Cable 1" 18 Gauge Brad Nails [Misc.]
Driver not moving up to fire position
I have broken a plastic peice probably from hitting it to get the plunger to move to the up position. why will the plunger (driver) not move to the up position.
  • 2,176 Answers
Dont have your model number but can come up with a few ideas. First the driver blade might be bent, the piston ring/cylinder might be scored or just dry and can't move freely and you could possibly have a nail jammed in the magazine restricting movement. Get back to me with the model number and I will look at a breakdown and see if I can find anything else. Also have you taken the tool apart? Let me know
Posted on Jan 21, 2009
Nv45ab won't advance nails
The allen screw/s that you mention are there to plug holes where automatic equipment would normally connect (such as automatic nailing machines) . This is only a plug and should not be driven in too far. I have also seen allen screws installed in the head to repair small crack/s.
Jan 22, 2013 | Hitachi Air Tools & Compressors
Hitachi NV45AB won't advance nails
This problem could be caused by the head gasket fliped the wrong way not sealing small hole in the body. Also the head valve gasket (small round gasket between headvalve and head) could be place with vent hole mis-aligned. Check these two items and post again.
Jan 22, 2013 | Air Tools & Compressors
The ignitioe will not turn out of the off position, the steering column will not lock and transmission shifter depresser button presses but will not move out of park.
SOUND LIKE IGNITION SWITCH KEYLOCK CYLINDER BROKEN. IN WHICH YOU CANT GET CAR OUT OF PARK.THE KEY LOCK CYLINDER BY TURNING THE KEY.IT MOVES A GEAR AND RACK ASSEMBLY THAT IN TURN MOVES THE IGNITION SWITCH ACTUATOR ROD AND PLUNGER TO VARIOUS POSITIONS REQUIRED FOR PERFORMING IGNITION SWITCH FUNCTIONS. IF KEYLOCK BROKEN YOU WONT BEABLE TO TURN IGNITION KEY OR GET CAR OUT OF PARK.
Mar 26, 2011 | 1999 Oldsmobile Alero
My finish nailer will not shoot fireing plunger does not go back up when fired
The driver attaches to a piston. If the driver has broken it will not return up it is either broken off the piston or an o-ring has went bad around the cylinder. After firing these o-rings direct a shot of air under the pist so it moves back up. What make of gun do you have?
Nov 17, 2009 | Senco Tools & Hardware - Others
STRIKER NOT HITTING PRINTWHEEL
The plastic cap on the print solenoid plunger is probably broken.
We sell them W/ instructions for installation for 20.00 tncluding
shipping.
DickyO
216-241-0027
Jun 24, 2009 | Lexmark Wheelwriter 1000 Typewriter
N80CB - Coil Framing Nailer firing plunger stuck
There is a number of reasons that this will happen. Is the driver (plunger) physically stuck? Take a small screw driver and see if it can manually be pushed back. It may also be a broken head valve spring, or a stuck head valve (you have to remove the rear cap to get to these parts) Maybe this unit just needs an O-ring kit. Try these things and let me know
Apr 02, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Ibm ww1000 hammer solenoid is not working .lack of impression
The plastic cap on the silenoid plunger is probably broken, thet are availabe but a little rticky to install. We sell them for 15.00 including shipping.
Cleveland Business Machines
216-241-0027
Dec 10, 2008 | Office Equipment & Supplies
Analog stick
mine did the same thing. buy a new one
Nov 20, 2008 | Microsoft Xbox 360 Controller
IBM Wheelwriter 3
You probably have a broken plastic cap on the print solenoid plunger, they are available but a little tricky to install.
DickyO
Oct 07, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 5 not printing
The print solenoid is under the ribbon just inside the L. printer side frame. When you type with the ribbon off you should see the plunger go in and out (a very short movement) on the back of the plunger is a plastic cap (clear to yellow from age) if the plunger moves and the yoke dosen't move or just bobbles a bit this is broken it is available from us for 15.00 includes shipping butcan be a little to install.
DickyO
Aug 21, 2008 | IBM Wheelwriter 30 Typewriter
Porter Cable 1" 18 Gauge Brad Nails [Misc.] Logo
907 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
