Question about Samsung RF4267HARS Stainless Steel French Door Refrigerator
Drawers won't slide out far enough
Flex Door and Freezer drawer don't slide out far enough to access the food items.
Sea Breeze
  • 4655 Answers
SOURCE: Samsung RS2545 side by side refrig, the drawers in
Because your refrigerator has dual evaporators you can start by defrosting. Yes the old time defrost. Once the ice is gone on the refrigerator side lets try slowly adjusting the fresh food sections to temps acceptable to the foods safe temperatures. I will send you the service manual but if a sensor has malfunctioned you may need to call or order parts. Sea Breeze
Posted on Jun 27, 2009
  • 7 Answers
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Posted on Oct 09, 2009
  • 15 Answers
SOURCE: Temperature showing on door indicates freezer is
Un plug the fridge and remove the top plastic hinge cover...There is a connector there that is for the control panel. Disconnect and reseat that connector...If there is a glob of hot glue there it may keep the connector from totally seating together. Remove the glob of glue.....
Re-apply power and see if that helps...
This fridge is a comptuter controlled machine. It is extremely complex in it's operation....Bummer.....I have one and have worked on it for 3 different problems...
Most service guys are just going to throw parts at it.....they have no understanding of the operation of it...
Here is a link for the service manual that may help if someone in the family can follow instructions...Nice tests....
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Good luck....
Posted on Apr 12, 2010
  • 9 Answers
SOURCE: There is an ice build-up underneath the humidity
The problem isn't the humidity control or temperature control. When the refrigerator automatically defrosts it goes through a cycle of heating and melting the ice build-up then drains this water to a tray at the bottom of the refrigerator (underneath). The drain tube that lets this water flow down to the bottom tray freezes so the ice begins to build inside the refrigerator section.
The solution to this is to defrost the tube so water can flow again. There are heating coils in the freezer section behind the plastic in the back that you must remove and defrost.
This is an inherent problem with a lot of refrigerator/freezers. You should probably have your refrigerator serviced and to check the heating capability of the coils to keep this tube from freezing. Otherwise put this on your monthly schedule of manually defrosting.
Posted on Sep 24, 2010
SOURCE: samsung rf265 series french door
I am having the exact same problem. Please email me if you find the solution. Our water eventually freezed to a sheet of ice. Some water leaks to floor. CCountess@aol.com
Posted on Sep 09, 2011
Freezer is Frozen shut
Try unplugging the freezer and leave the door open for about 30 to 45 minutes. Don't forget the door is open and plug the freezer back in. Set a timer in the kitchen so you don't forget. Once you can open the drawers look inside the freezer sides to find the controller. Most models have turn dial inside.
Mar 07, 2012 | Siemens Freezers
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hotpoint FFA70 - Freezer door will not close properly.
The rear panel can be removed,i have done it.I removed the 4 hex head screws from the top & bottom of the panel,and firmly pulled it forward.The reason i say pulled firmly is that when panel came out the back of the freezer was solid with ice.I have defrosted the freezer,dried any water from the unit and replaced the panel.Fingers crossed,so far,so good.In my case this build up of ice was definately the reason the drawers were not sitting in the correct position,as it caused the rear panel to 'bulge' out.Hope this helps.....
Dec 11, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
My FFa70 hotpoint freezer will not close unless i take out all the drawers. What is the problem?
there is something wrong with the drawers position. they could have been installed in the reverse position or they could have been in the wrong placement. one could be on top while the other could be at the middle.
try putting the drawers one by one and check each time if the door could be close by then.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Refrigerators
Hotpoint FFS70 freezer door won't close
there must be a basket that is bent ,
Jan 18, 2008 | Freezers
Samsung RF4267HARS Stainless Steel French Door Refrigerator Logo
19 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
