Question about Car Audio & Video
1997 ford thunderbird lx, i installed an aftermarket pioneer head unit( radio) a fairly simple swap no sub or amp, just the head unit. Worked fine for a few weeks then just kicked off head unit is fine, speakers are fine all work out of the car (tested in another car to be sure) all fuses in the engine compartment and under the dash including the one on the head unit itself are good im lost what else do i check?
  • 14 Answers
SOURCE: speaker Problems
What are the outputs on the back of your stereo? & how are the front speakers wired up, to one of the amps or directly to the head unit?
If you have both amps just feeding the subs & the front speakers connected to the stereo then there should be a setting somewhere that allows you to do this. Have a look on the stereo, some have a switch on the back so that you use one or both internal amp for small speakers & the output for amps.
Posted on Dec 28, 2007
  • 507 Answers
SOURCE: My aftermarket radio will not turn on
I assume you didn't install the radio yourself then? Some installers put a inline fuse in. This would be located behind the radio. Some radios even have a fuse built into themselves, also on back side of radio. If those two solutions don't help ya, check the other fuses. Maybe the wiring for the radio was hooked into a different system other then the radio.
Posted on Sep 14, 2008
blueextc3221
  • 15935 Answers
SOURCE: Amp is shutting off after 10 min of driving!! please help!!
Does it happen at all volume levels?
What is the gain setting on the sub amp?
Have you checked for 12V @ remote turn on after problem occurs?
Sounds as if the remote turn on relay inside the amplifier is losing signal, or has become damaged. If the protection light does not light up, the problem is not thermal, shorting, or high/low voltage.
The amplifier is in need of repair. This is not an end-user fix. Looking at about $50 to repair.
Thanks for using FixYa- a FixYa rating is appreciated!!
Posted on Feb 18, 2009
  • 773 Answers
SOURCE: PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Posted on Dec 15, 2009
  • 93 Answers
SOURCE: Pioneer GM-7200M Car Audio Amp appears to fine but wont work
check the rca input leads are ok
Posted on Dec 30, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
Why does my aftermarket Pioneer radio blow fuses after a few minutes of operation?
what is the model of your pioneer and these luminas have the amp built right into the stereos same as the 98 same deal
Apr 15, 2015 | 1997 Chevrolet Lumina
How to install oil sending unit 1997 ford thunderbird
It just screws into the engine block or the oil filter adpater.
Nov 05, 2012 | 1997 Ford Thunderbird LX
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Do i have to remove my timing belt in order to replace my water pump in my 1997 ford thunderbird lx its a 4.6 v8
Your car use3s a timing chain not a belt. The water pump will be serviced by first removing the serpentine belt and then removing the water pump pulley and then finally removing the water pump. It is a fairly easy pump to replace.
If you have any further question please ask I I will be happy to help.
Aug 14, 2011 | 1997 Ford Thunderbird LX
Subs not responding to Sony CDX-GT500
you cna switch the working rca's to the sub out put to check for sound if u get sound it means your rca's are bad but if no sound then your other outputs in your radio may be deffective
Jun 12, 2010 | Sony CDX-GT500 CD Player
"97 T-Bird...blinkers stop & start
it sounds like you need to replace the flasher unit under the drivers side dash
May 08, 2009 | 1997 Ford Thunderbird LX
1997 Saturn After Market Radio
The Aftermarket Stereo's have a Built in Fuse in the Power line coming from the Head Unit. Check here and let me Know.
Jan 10, 2009 | 1997 Saturn SL
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
