Question about HP Pavilion M703 17" CRT Monitor
Greeen!!!!!!!!! ok this is kinda weird problem. my monitor's green values keep changing from normal to some high values making the picture look irritatingly green. it becomes normal after some time though. I've tried alot to find out when the color is changing(i mean with any change in external factors) but i couldn't. and recently i've also seen the red values changing. Im gettin so mad that one day i'll surely break the monitor. one more thing i forgot to mention is that the gui menu colors of the monitors have normal colors even when the rest of the screen becomes green. Plz help me out i'll b greatly thankful for u.
  • Rahul Dev Jul 01, 2007
    i've tried degaussing but no use. i knew that last point would help u cuz i too thought something same. so can i do it myself or do u want me to take it to some professional?
  • 432 Answers
You can try to Degauss the monitor. It still sounds like the video cable is bad. That last part you mentioned about the OSM (on-screen Menu) having normal colors comes from the monitor and has nothing to do with the cable or pc. That tells me its the video cable, or the video cable connector (pins maybe bad) or a bad connection somewhere. There could be a bad connector inside the monitor where the video cable is attached to the electronics board. Sometimes those contacts just get oxidized and quit transmitting a signal. They need a good cleaning.
Posted on Jul 01, 2007
SOURCE:
WHEN I SWITCH COMPUTER ON THE SCREEN IS GREEN - WHY
Good day!
Defective cable, defective VGA device, corrupt drivers or a failing monitor.
Visit HPParts us Computer Parts Power Supplies Electronics Hard Drives...
Jan 21, 2013 | HP Pavilion F1523 15" LCD Monitor
I need to know the speaker wire colors for a 1994 toyota 4runner limited
According to the book it is: right speaker-1 light green with black 2 blue with red 3 light green with black 4 blue with black...left speaker:1 light green with blue 2 light greeen 3 light green with yellow. This out the book, if you dont under stand because wiring diagrams are hard to read, get back to me and i'll see if i can send you a picture of it ok.
Aug 20, 2011 | 1994 Toyota 4Runner
My monitor is all weird colors
Generally, this is caused by the loss of one of the main color inputs (Red Green Blue). Do the Following:
  1. Check the cable connections at both the monitor and the computer. Look inside the connector for any bent bent pins (there may be some that appear to be missing, generally that is normal) then reset the connections firmly and tighten the retainer screw snug, but not extremely tight.
  2. If that doesn't resolve, try the monitor on a different system and see if the problem follows the monitor. If it does, try a different cable. If the problem doesn't occur on another system, then the video card of the effected system is suspect.
  3. If issue occurs on multiple systems with known good cables, then the monitor will need replacement.
Dec 21, 2009 | Computers & Internet
PANASONIC PT-46G40U CONVERGENCE PROBLEM HELP...
Have you checked the bias resistors for Exact Value. They normally change value when the stk's take a dive.
Dec 09, 2009 | Panasonic PT-46G40 46 in. Rear Projection...
Greeen filter?
?? the colour of the OSD is OK but the rendering of your video signal from the 'pooter is wacky? Either the video cable or video drive from the 'pooter is the cause.
May 01, 2009 | Acer AL1912 19" LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
My moniter has these weird lines beside dark areas
i have the same monitor. you might be able to purchase new cords for the monitor or it might just be the monitor itself if it is you will need to get a new one.
Oct 23, 2006 | BenQ FP71E 17" LCD Monitor
HP Pavilion M703 17" CRT Monitor Logo
108 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
