The temperature on the freezer does not stay and the control on the panel is always blinking.
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
SOURCE: side by side kenmore refrigerator
defrost system not working. take back plate off freezer. checkdefrost heater and any stats mounted on the pipework
SOURCE: Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
SOURCE: Refrigerator will not stay cold
Eeeh, this will prevent you to spend more than you have. Carefully unplug your fridge, remove it from the wall for about 1 foot wait 15 mins and plug back and let it stay there for ever.
