Question about Maytag Bravos 7.3 cu. ft. Gas Steam Enhanced Capacity Dryer - MGDB850W
Bravo gas dryer flame on flame for 10 sec then off constantly
Once you start my maytag model MGDB850WLO it ignite every ten seconds then goes out
  • 76 Answers
SOURCE: After first Ignition cycle igniter stays on too briefly to open gas valve gas.
Valid Most likely the problem with your dryer is the coils for the gas valve. Remove the access door (on the bottom right side on the front panel) and you can see the gas valve with three coils on top of it. They are coming as a kit with complete instruction. The part number for this kit is AP2669614.You can buy it here http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542517043&type=10&subid=
Posted on Jan 16, 2007
dutchman05
  • 487 Answers
SOURCE: MAYTAG MDG6200 AWW flame keeps keeping going out
Your thermostat is broken.
I think the gas 5 wire or the heat limit
FOR THESE PARTS LINK
or what i would check first is the fuse on the blower housing which is a thermal fuse. A regulat ohm meter /resistance meter can do the trick. No resistance should be measured or very low on this fuse. If uninfinit restistance this one is broken.
It can also be the limit thermostat . Measure when cold. > low resistance.
This is another link for PARTS
Good luck
Posted on May 04, 2008
appldoctom
  • 311 Answers
SOURCE: Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Posted on Jan 02, 2009
localwonder
  • 6784 Answers
SOURCE: the heat (gas flame) goes out after dryer has been
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
This could also be caused by a bad set of coils as well. the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
**The most common problem spot here will be a defective set of gas valve coils.
Posted on Jul 08, 2009
Illeagle
  • 525 Answers
SOURCE: Gas dryer ignites at start up then cycles off, won't re-ignite
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedures for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
The link below shows an image of the gas valve coils, which is the most common failure component in the system.
1. Gas Valve Coils:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG3000AWW-%3d%3di3479&PartID=3479
Below are some tips to follow if the coils are not faulty.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Posted on Aug 28, 2009
Oven kicks on gas lights runs for 10 sec then beeps showing preheat is done then kicks off
I had to replace my igniter to get mine to work. I did it myself for $65.00 Mine the gas just would not stay on to heat up.
Mar 13, 2015 | Maytag Ovens
I have a maytag gas dryer MODEL ldg8404aae, I replaced the Ignitor, now the unit will ignite, but will only stay lit for about 8-10 sec, can you help me
It might be a clogged vent make sure it is clean and has no obstructions, also it could be a bad themostat. Check the one right by the flame.
Jun 13, 2011 | Maytag Dryers
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't dry
That is a bad gas valve, change it.
Sep 02, 2009 | Dryers
My kenmore gas dryer ignites and the flame shuts off after 10 sec
The valve on the pilot may need to be replaced. The springs get worn and wont stay up. Otherwise you could replace the entire pilot unit with a kit.
Jul 20, 2009 | Kenmore 74602 Gas Dryer
Maytag Gas Dryer - Flame starts and then turns off 5 seconds into cycle
HI thanks for your question. the coils on the gas valve are faulty . common problem with gas dryers , replace the coils thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Maytag Dryers
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Gas dryer
hi. no not now. i would check the venting. clean the venting. thanks the appliance doc
Oct 03, 2008 | Kenmore 73932 Gas Dryer
Jan 16, 2007 | Maytag MDE2706 Electric Dryer
Maytag Bravos 7.3 cu. ft. Gas Steam Enhanced Capacity Dryer - MGDB850W Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
